ITR 98 5 lug conversion on a 93 civic si?
I have a itr 5 lug conversion that I ordered and need to know. What do I have to do to fit the front hubs? I am running a d motor and I heard that the axles sizes are different? Thanks for the help.
if you ordered a "JDM" 5 lug then you will need the jdm axles, i think are 36mm.
the jdm axle's are bigger, then usdm. so your oem axles will not work with the jdm 5 lug. from what i understand....
if it is a usdm itr or even a ctr then the axle sizes will be okay. HTH
all this applies to USDM vs JDM, so depending on where you are at..... Guam was it????
the difference is only on the JDM 98+ Spec knuckles/hubs. all USMD and JDM CTR 5bolts used the 32mm standard d/b-series size.
JDM 98+ 5bolts used 36mm ala CRV (look into the outer joint)
You need to get the 98+IRT outer shafts or another 36mm spline i'm not sure if there is another. Or you could order new bubs and bearings I think and just convert it to 32mm spline.
I just got the JDM CTR 5 lug
https://honda-tech.com/zerothread?id=891751
jc2801
Jun 7, 2007 10:05 AM
B18Redline
Jun 12, 2003 11:39 AM
oem
10
Jan 27, 2003 08:53 PM
Lenthrax
Sep 27, 2002 08:36 PM
