HELP: will a 1998 JDM itr 5 lug suspension bolt onto an 1999 honda civic coupe?
I know a 98 usdm 5 lug itr suspension will bolt onto an 1999 honda civic coupe, but what about the 98 jdm 5 lug??? is there any difference between jdm and usdm 5 lug suspension?? Any advice is appreciated. Thx
Re: HELP: will a 1998 JDM itr 5 lug suspension bolt onto an 1999 honda civic coupe? (utboi)
I won't pretend I know alot about 5-lugs, but I believe it should all bolt up. Correct me if I'm wrong but I think you'll need a larger axle size...
it will all bolt up except your axles. the 98-up JDM itr 5lug uses jdm 36mm axles where as the USDM and JDM CTR 5lug use 32mm axles (the more common US bseries axle). other than that everything else is the same. hope that answers your question
Re: HELP: will a 1998 JDM itr 5 lug suspension bolt onto an 1999 honda civic coupe? (Kid1320)
Just wondering where you are buying the JDM 5-lug from. I am also looking for a 5-lug (preferably JDM w/ JDM ITR wheels). Please let me know where your buying from.
Thanks,
Jake
Thanks,
Jake
Re: HELP: will a 1998 JDM itr 5 lug suspension bolt onto an 1999 honda civic coupe? (Chiller514)
If you have a b-series engine, you can use the JDM ITR 5 lug conversion provided that you also get the larger 36 mm axles. The USDM ITR and JDM CTR conversions will fit all Civics since they come with 32 mm hubs and 32 mm is the standard size in the US. If you have a d-series engine, you can only use the USDM ITR or JDM CTR 5 lug conversion because you can't get 36 mm axles for the d-series.
Re: HELP: will a 1998 JDM itr 5 lug suspension bolt onto an 1999 honda civic coupe? (EricUSC)
Dseries motor fits the Bseries axles?? if i take a gsr/itr axle (32mm) and put it in the Dseries half shaft and tranny, it will work??
I may be wrong, but I think the lengths are different and the diameters are the same.
If your interested, i know someone else selling a set in Toronto. $1200 including gunmetal rims. pm me
I'm pretty sure B series and D series axels are not compatible. If you get the JDM 5-lug you must have JDM axels (36mm). If USDM 5-lug it has to be USDM axels (32 mm). JDM and USDM B series axels will both work on any B series engine but the JDM axels must be used with JDM 5-lug and USDM with USDM.
-Jake
-Jake
thanks for all the help.. jdm 5 lug will be going in this weekend
jc2801
06-07-2007 10:05 AM
RhdDc2R
Suspension & Brakes
02-16-2006 06:36 PM
l2p
06-11-2004 07:27 AM
oem
01-27-2003 08:55 PM
