***ACCEL DFI STANDALONE ENGINE MANAGEMENT***
Old Jun 10, 2004 | 12:26 AM
JDMotive's Avatar
Default ***ACCEL DFI STANDALONE ENGINE MANAGEMENT***
Ive got an ACCEL DFI gen 6 ems for sale.It is a complete standalone fuel and spark management for most cars.It has 16x 16 maps for fuel and ignition and can control a 3 bar map sensor.It includes:
ACCEL ecu
wiring harness
software
communications cable
and a gsr distributor with msd cap,modified to use only the tdc sensor,which is all the accel needs.
It was running on a ls/vtec crx for awhile..ran consistant 12.3's NA and high 10's when it was turboed.Asking $450 obo..price IS negotiable and will accept trades for rsx/2k2-2k4 k20 related parts(shift cables,axles,ecu,harness etc)
BTW..the model number is 74043a with 74040-i mod
Old Jun 10, 2004 | 04:59 AM
bruthaboost's Avatar
Default Re: ***ACCEL DFI STANDALONE ENGINE MANAGEMENT*** (JDMotive)
I'm very interested. Do you know of any sites where I can read more about this system?
Old Jun 10, 2004 | 08:52 AM
JDMotive's Avatar
Default Re: ***ACCEL DFI STANDALONE ENGINE MANAGEMENT*** (bruthaboost)
http://www.mrgasket.com is the only place i know of.
Old Jun 11, 2004 | 09:45 AM
JDMotive's Avatar
bump
Old Jun 17, 2004 | 02:17 PM
alteredautosports's Avatar
I am intrested but what are you switching to?
Old Jun 17, 2004 | 02:42 PM
JDMotive's Avatar
Default Re: ***ACCEL DFI STANDALONE ENGINE MANAGEMENT*** (alteredautosports)
Im running a different engine now.Im probably going with an AEM ems.
Old Jun 17, 2004 | 08:35 PM
DIRTY FACE's Avatar
free bump cuz I want it
Old Jun 17, 2004 | 08:47 PM
JDMotive's Avatar
Default Re: (DIRTY FACE)
Buy It!!!! Remeber,the price IS negotiable and i might accept trades.I need 91 crx si rear calipers,coilovers,a few autometer gauges,universal fuel pressure regulator etc...Let me know what youve got,i may want it.
Old Jun 29, 2004 | 10:40 PM
paulzy's Avatar
I might take it...let me think it over. Does it come with some kind of harness and sensors?
Old Jun 30, 2004 | 08:42 AM
JDMotive's Avatar
Default Re: (Paul_Vang)
It comes with a harness...one piece from the ecu to the engine....it uses GM sensors,though ive only got the 3 bar map sensor..and comes with a modified gsr distributor,which uses only the TDC sensor.
Old Jul 3, 2004 | 11:13 AM
dome's Avatar
Default Re: (JDMotive)
hay i have 4 autometer guages brand new in the box, oil, fuel pressure, volts, water temp............
Old Jul 3, 2004 | 11:37 AM
JDMotive's Avatar
Default Re: (dome)
Me too
Old Jul 3, 2004 | 03:48 PM
dome's Avatar
well you said let you know what i have..... sehttps://honda-tech.com/zerothread?id=914045 see if you can help me out with this
Old Jul 3, 2004 | 04:12 PM
JDMotive's Avatar
Default Re: (dome)
Oh ok...well that link isnt working for me....what else do you have?I do need those gauges for the race car,but they are only around $50 a piece which would be only $200.
Old Jul 3, 2004 | 08:09 PM
dome's Avatar
https://honda-tech.com/zerothread?id=914045 and 150 bucks. eveything working with the ecu. and what was the set up in the ecu. my car should dip in the 10s. just wondering if the map you have in there might be good for me. just might have to clean it up a little
Old Jul 4, 2004 | 10:45 AM
JDMotive's Avatar
Default Re: (dome)
Your DFI and $150 for mine?Whats wrong with yours?Mine was setup for my all motor car...ls/vtec,13:1 compression,CTR cams,440cc injectors etc..
Old Jul 4, 2004 | 07:08 PM
dome's Avatar
no not my ecu. that was the post i wanted you to read to see if you could help me out. i have the 4 guages and 150 bucks or i have a spearco air to water intercooler that is powdercoated. i have no need for it never used it. i thouuht it was on a turbo car. so you used the same map from the all motor car on the turbo car...........
Old Jul 5, 2004 | 06:21 AM
dome's Avatar
Default Re: (dome)
did you want any of this.........
Old Jul 11, 2004 | 06:18 PM
dome's Avatar
hay did you want to sell this.............
Old Jul 12, 2004 | 09:46 AM
JDMotive's Avatar
Default Re: ***ACCEL DFI STANDALONE ENGINE MANAGEMENT*** (dome)
I need to sell asap.
Old Jul 12, 2004 | 10:10 AM
Liltrix's Avatar
I need the 7, if you had it I would have jumped on it, however I have some friends who were looking for a Stand alone I will refer them to you
Old Jul 12, 2004 | 10:20 AM
JDMotive's Avatar
Default Re: ***ACCEL DFI STANDALONE ENGINE MANAGEMENT*** (Liltrix)
Thanks..let me know if any of them wants it.This EMS is very good,but the 7 is better/newer,but also alot more expensive.
Old Jul 13, 2004 | 02:40 PM
I would like to know if you wanted to trade I am looking for a more streetable body I have to trade brauning motorsports tube chassis from there 2000 civic all motoro car and a 94 delsoll shell that has been cut to fit it. They retired this chassis in 2002 and it went 10.93 122mph I purchased it but no longer have time to finish it. I am building a hotrod class car at this time so my time is taken. email me for more info like my number if you are intrested.
ianandamy@msn.com we may be intrested in the dfi also.
I have pics to email if need
JDMotive
May 23, 2004 02:40 PM
Boosthead
Sep 30, 2003 06:46 AM
Boosthead
Aug 25, 2003 06:06 AM
paybac4223
Jan 29, 2003 09:57 AM
