Smog and Timing Help
Old Jun 10, 2004 | 12:11 AM
jefe's Avatar
Default Smog and Timing Help
Hey all. Sorry if this is a repeat post. I checked the archives and couldn't find anything specific about my questions.
I am new to Cali and went to have my car smog tested today. 93 Civic HB. 132,000 miles. Pretty much stock engine except for aftermarket intake and exhaust - Greddy headers and pipes with a 5-Zigen can on the back. Original Cat. The Greddy part of the exhaust is probably 4 years old and the 5 Zigen can about 1-2 years.
My car miserably failed the smog test. SUCK!
First problem is my intake not being Cali legal. No problem. Easy enough to fix.
2nd problem is that my timing is crazy advanced to 20 degrees. Must have f***ed it up when I recently swapped out my water pump. This probably explains why she randomly dies on me sometimes.
Was curious, in everyones experience, if it would be cheaper to take it to a shop and have them adjust the timing back to 16, or if buying the tools needed to do it myself would be cheaper. Not sure what I would need to adjust the timing myself and how much it would cost. Any thoughts on that?
3rd problem was the fact that my car was emitting high levels of the gases they check. So I apparently have to take the car and have it diagnosed to tell me what other problems I am having. I know my car is old with alot of miles on it, and that there could be a million things causing the high levels.......but was wondering if anyone else had a similar test result and/or what else I can expect to be wrong with the car.
I'm in a tight situation with money and am looking at a minimum of $150 for a new intake, timing adjusting, and a diagnosis. Any insight, tips, advice, or good lucks would be much appreciated.
Thanks all. - jefé
Old Jun 10, 2004 | 12:21 AM
2 point 0's Avatar
Default Re: Smog and Timing Help (jefe)
just go to a shop to get your timing done. i went to 2 different shops and they both did it for me for free.
Old Jun 10, 2004 | 12:22 AM
jefe's Avatar
Default Re: Smog and Timing Help (2 point 0)
no kidding? I went to a shop today and they wanted $40-some. Sounded steep to me. Plus another $60-some to diagnose why the car failed.
jefe
Old Jun 10, 2004 | 12:45 AM
jefe's Avatar
How much does a timing light cost?
Old Jun 10, 2004 | 06:17 AM
trooper0641's Avatar
what the hell...timing your car should be around $20- ish @ a shop. Timing guns...@ auto zones are $30-$40.
Old Jun 10, 2004 | 07:58 AM
jefe's Avatar
Default Re: Smog and Timing Help (trooper0641)
So is that all I would need to adjust my timing? A timing light and a few tools?
Old Jun 10, 2004 | 08:50 AM
Deemeetree's Avatar
Electrician
All you need is a timing light and an open box wrench to loosen the distributor bolts to advance or retard.
Ls2DxMoon
Oct 7, 2013 08:19 AM
_ijayyy
Jul 4, 2012 01:49 AM
mish__
10
Oct 5, 2011 06:09 AM
Green Deli
Sep 16, 2009 06:17 PM
dc4teggiehatch
May 4, 2008 08:17 AM
