2.25 exhaust diameter too small?(searched)
i seaarched, and most apps are 2.5 inches and 3 inches for turbo apps. i was wondering if a 2.25 would be that obstructive on a low turbo set up, like on a greddy turbo kit. thanks
The general concensus is that the least amount of backpressure with a turbo the better. That is why so many people run open downpipe. You really should run something a little bigger but you could get away with 2.25.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">i am uaing my 2.25 crush bent exhaust for now on mny 9 psi setup
and it hauls *****
i cant wait until i get the full 3", i know i will feel a good 20 hp gain with that</TD></TR></TABLE>
20 ho.. are you serious?
and it hauls *****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo »</TD></TR><TR><TD CLASS="quote">
20 ho.. are you serious?</TD></TR></TABLE>
depengin on how extreme his setup is, and if its on stock... could be possible
must likey a "feel"
must likey a "feel"
am I the only one who thinks that 2.25 is reasonable? it definately not optimum, but if it's 2.25 all the way back and is mandrel bent, I don't think it will be too bad.
granted you might want to drop it for the track, but on the street I think you'll be ok
yes i am
i know theres a lot of backpressure being held with that exhaust... i can feel it on top end...
the 20 whp will be a more climbing peak after around 3500.......... IMO without all that backpressure the turbo will do more of what its supposed to..... if i can get a dyno with it and without ill post it......
i am waiting to get a TE chipped PM6 before i go tune it
yes i am
the less backpressure the better--- i switched from a 60mm greddy to a full 3" and it was night and day. i honestly woudl never do a turbo kit again unless i did a 3" downpipe and 3" exhaust.
get a 3": increase spool time, high end, power output, and gas mileage
and we all know thats why we put the 3" on there!
Talk to GSRwBoost about this, I think his GSR had about 300whp on a Greddy 60mm (2.36") exhaust. Low power setups (<250whp) will have less to gain from a big exhaust than a big power setup. Your Greddy turbo setup will probably not lose too much to the 2.25" exhaust, but you'll need to switch it out if you upgrade to a more powerful setup.
the book maximum boost said that 2.5 mendrel bent exhaust is good till 500 hp. i know its not optimum, but... if youre gonna be running on a small turbo (t25, greddy kit 19t, 14b) and low boost, how much are you gonna open up between a 2.25 exhaust or a 60mm and a 2.5?
Guest
Posts: n/a
maybe 10 hp? Your right 2.25 or 2.5 will work. But you will always get better gains on bigger exhaust, that way you have the LEAST amount of back pressure. 2.25 is fine if you arent too worried about getting the most out of your engine.
xmr. robotox
Jan 20, 2005 01:18 PM
arsenaldragster
Jul 20, 2003 01:49 PM
