Cutting Cam Cover for Toda Gears?
Old Nov 13, 2001 | 03:34 AM
N1Spec's Avatar
New User
Default Cutting Cam Cover for Toda Gears?
hi guys, ive done a search came up with zilch!!
ive got a dremel tool, is that sufficient for cutting the cam cover? and wat dremel bit did you guys use? Im just gonna cut it in a rectangular shape not the 2 circular ones that ive seen some peeps do. Also while your at it please post some pics..........
cheers
Old Nov 13, 2001 | 03:57 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Cutting Cam Cover for Toda Gears? (N1 Spec)
i drilled 2 holes, one in each corner of the side of the valve cover then used a air powered mini saw (sawzall might work, but a little bulky) to cut 3 straight lines. i then used a rotary grinder to smooth all the rough edges.
Old Nov 13, 2001 | 04:19 AM
Willard's Avatar
Dremel with the ~60-70mm dia. fibrous disc.
It took me ~20 min. (with rests) to make the 3 cuts on the cover.
If you make the 3 cuts parallel to the outside edge of the cover (no just a rectangular hole) the cutting is a lot easier. You will wind up with a modified rectangle but still looks nice.
"ITR009" (Pat) had one of the covers that I worked on. "BlackR" has it now... I think.
Will
-who wished he had pics
Old Nov 13, 2001 | 05:30 AM
N1Spec's Avatar
New User
Default Re: Cutting Cam Cover for Toda Gears? (Willard)
cool.....
wow a 60 - 70mm disc? the largest ive seen for a dremel is 30mm i think. I'll go look for it tomoro.
i also know what u mean by cutting it parallel to the edge, thats what i'll probably do....... cheers mate!
Old Nov 13, 2001 | 05:32 AM
Black R's Avatar
25 Year Member
.....I'll post pics when I put it on. Will do valve lash adjustment before the end of the month and the switch will happen then.
Will's work is
I was gonna sand down the rough edges... but there aren't any!
Old Nov 13, 2001 | 06:25 AM
Willard's Avatar
Default Re: Cutting Cam Cover for Toda Gears? (Black R)
And to think... I was heavily sedated by beir all 3 times I have cut covers... It's a wonder they were even cut on the correct end...
Those ~60mm discs are expensive! maybe $1.50 (US) each or close to that. I will try to get a part # for you N1.
Willis
Old Nov 13, 2001 | 06:34 AM
Splat's Avatar
Collector-o-Guns and Drinker
Yesh, Willard did an excellent job with my valve cover. Glad you're happy with it, Ken.
Old Nov 13, 2001 | 07:04 PM
Willard's Avatar
Sorry for the wrong size... 30-35 mm disc is the correct size.
If they were 50-60 mm they would last a lot longer...
Pack #426
"Fiberglass Reinforced"
5 per pack
Will
Old Nov 13, 2001 | 07:32 PM
N1Spec's Avatar
New User
thought so.....
fuq that shiet is expensive, $25 AUD for 5.
Old Nov 13, 2001 | 07:38 PM
Bloodwynch's Avatar
Yeah dremel bits in Aust are a rip off!
I got some heavy duty cutoff wheels for 13 bucks at hardwarehouse
Old Nov 13, 2001 | 07:40 PM
ThePunk's Avatar
Default Re: Cutting Cam Cover for Toda Gears? (Bloodwynch)
3" Holesaw....
Old Nov 13, 2001 | 08:27 PM
integRated109's Avatar
i used the dremmel, the wheel to get the square shame, and then i used a sanding wheel to shape it up a little. there is a decent pic on my website(sig) under members, and mike. id post it but its big and i cant resize it from this computer.
Old Nov 14, 2001 | 04:12 AM
Lip's Avatar
Lip
Default Re: Cutting Cam Cover for Toda Gears? (ThePunk)
4"
Old Nov 14, 2001 | 06:56 AM
AssPenny's Avatar
Default Re: Cutting Cam Cover for Toda Gears? (Lip)
Jason (Typer98) and I used a Dewalt Jig saw, cut through that **** like hot butter. Took us all of 3 min.
I'll see if Jason will take a picture of the cover.
[Modified by AssPenny, 7:57 AM 11/14/2001]
Old Nov 14, 2001 | 07:05 AM
BryanSprinkel's Avatar
Default Re: Cutting Cam Cover for Toda Gears? (AssPenny)
I second that, my dumbazz used a hack saw the first time
Bryan
B18C Turbo
Oct 6, 2005 05:26 PM
quicksol95
14
Apr 29, 2004 10:41 AM
fe519
Dec 20, 2003 10:34 AM
oryanh
Jan 6, 2002 09:48 AM
Scary1109
Dec 15, 2001 10:00 AM
