Suspension help
I cant seem to be able to post anywhere other than here so maybe you guys can help me.
I am thinkning about getting TEIN BASIC's for my 91 crx but I was told koni yellow and ground controls would ride better. I am only looking to "dump" my car I do not auto cross or anything like that. I want the lowest ride hieght with the best ride quailty i can get. THANKS
Well if you wanted to drop it alot and you want a good ride then you might want to get an entire new suspension setup. The stock shocks can only be dropped so far because the shock will have nowhere to travel if your car goes over a bump. Not good. Tein is expensive but probably the best you can buy. Im not sure how much it drops it but that would definately give you the best ride. The konis and ground controls are a good match but i dont think you can beat tein (personal opinion).
^^^^ thats the look I want.
Tein BASIC's are only $650. I would spend that much on koni yellows and GC C/O setup.
I would buy your ground controls but I have some other things I need to pick up first.
