Found some oil around threads of spark plug
Old Jun 9, 2004 | 06:59 AM
typeeg's Avatar
Default Found some oil around threads of spark plug
I have a b18c1. I took out my spark plug and it had some oil around the threads on each cylinder. First thought that comes to mind is bad/worn rings but if this were the case wouldn't the electrodes be drenched in oil as well? I checked the valve cover O-ring gaskets and they are fine. Any ideas?
Old Jun 9, 2004 | 07:40 AM
StyleTEG's Avatar
Default Re: Found some oil around threads of spark plug (StockEG9)
Usually its the O ring gaskets, but if your rings are worn it may be burning off what would be on the electrode.
Try putting a small amount of RTV around the o-rings next time, make sure to torque down the valve cover per the helms, and see if it goes away.
Old Jun 9, 2004 | 11:37 AM
Quitripin's Avatar
bummer, might want to change the gasket for your valve cover
Old Jun 9, 2004 | 01:37 PM
Witty's Avatar
Default Re: Found some oil around threads of spark plug (Quitripin)
My rings are shot and I have the same problem. It is usually caused by bad valve cover O-rings.
Old Jun 9, 2004 | 02:33 PM
BERT-O's Avatar
Default Re: Found some oil around threads of spark plug (Witty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Witty &raquo;</TD></TR><TR><TD CLASS="quote">My rings are shot and I have the same problem. It is usually caused by bad valve cover O-rings.</TD></TR></TABLE>
alot of people tend to replace Valve cover gasket first before the spark plug o-rings, at times
Moo Sid
Oct 30, 2017 09:26 AM
BI8B
21
Jan 30, 2005 12:58 PM
EnKidu
Dec 27, 2004 06:39 PM
EIT_certified
Aug 1, 2004 08:33 PM
quazar
Jun 22, 2004 06:46 PM
