Suspension & Brakes Theory, alignment, spring rates....
Koni /GC H22 spring rate IS it enough
Old Jun 8, 2004 | 10:13 PM
greatbiggiants's Avatar
Default Koni /GC H22 spring rate IS it enough
I have a 92 vx h22 lsd, i bought Koni sports and i just about to order GC, So is my spring rate choice going to be stiff enough in the (front), 400/500 rates. I know 500 is good for the rear. OR Should i get 450 in front??? Daily driver / drag track racing, and mountin runs.
Old Feb 4, 2005 | 04:48 AM
skater5067's Avatar
Default Re: Koni /GC H22 spring rate IS it enough (greatbiggiants)
wondering the same thing also wondering if i got the gc now with out with koni yellows and i plan on getting them later would i have to buy new coilovers to fit them or is there a adaptor or something that it will work with?
Old Feb 4, 2005 | 04:54 AM
menkio's Avatar
Default Re: Koni /GC H22 spring rate IS it enough (skater5067)
this is actualy a tough question, being the h22 is a bit heavy, esp over a d series, i would say yes, up the spring rate to 450, or even 500.. but i'm not as educated in susspension as i want to be. I would say, contact ground control, the number is 530-677-8600, they should help with your setup
Old Feb 4, 2005 | 05:50 AM
Buzzbomb's Avatar
OT: Sorry,
Skater, OMG your avatar, LMAO
Old Feb 4, 2005 | 07:31 AM
jmayhew's Avatar
Default Re: Koni /GC H22 spring rate IS it enough (Buzzbomb)
from all that i read when researching for s suspension for my h22 VX....i read that 500front/400rear was plenty
the aftermarket springs for the EG h22 swap range anywhere from 350front/200rear on up to 500front/400rear
the progress springs for that swap are 375/200
i ended up getting D2 coilovers with 9k/7k....aprox 500/400
Old Feb 4, 2005 | 07:36 AM
.RJ's Avatar
.RJ
give ground control a call they'll help you out
Old Feb 4, 2005 | 08:39 AM
skater5067's Avatar
Default Re: Koni /GC H22 spring rate IS it enough (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">give ground control a call they'll help you out </TD></TR></TABLE>
will probly end up doing that
H22EG'z
Suspension & Brakes
May 29, 2009 03:44 PM
SAVIOVEGA
Mar 10, 2004 10:34 AM
KENLUDE97
Mar 17, 2003 11:15 AM
