ODB0 hatchback +99 si B16A2 OBD1 programming. im confussed!
Old Jun 8, 2004 | 05:12 PM
95EXcivicsleeper's Avatar
Default ODB0 hatchback +99 si B16A2 OBD1 programming. im confussed!
ok i got a 1990 honda civic hatchback OBD0 (i think) hybridautomotive has a 99 si B16A2 engine with everything and it says OBD1 proggramming. ok im confussed because i thought 96+ civic are OBD2. anyways what i really want to knoe is if i get this engine do i have to convert my car to OBD1 even though the engine i want to get comes with everything and says OBD1 programing and wiring. someone help me out thanks.
Old Jun 8, 2004 | 06:29 PM
Default Re: ODB0 hatchback +99 si B16A2 OBD1 programming. im confussed! (95EXcivicsleeper)
some one anyone???
Old Jun 8, 2004 | 07:13 PM
Turbogixxer's Avatar
Two things:
A) They either converted it to OBD1
B) They said it can be easyly converted to run on OBD1
You can run OBD2 and its electronics on a OBD1 ECU. You would have to convert the harness if you use a OBD1 harness.
You catching me?
420eg
Jun 26, 2015 03:31 AM
crxb16a90
Engine Management and Tuning
Mar 2, 2010 04:42 PM
JJGL-EF90
Feb 17, 2010 08:07 AM
amazinspiderman
Feb 13, 2006 11:49 AM
B18 CYA
May 8, 2004 01:32 PM
