My new suspension!
Old Jun 8, 2004 | 04:11 PM
DC2-JRSC'd's Avatar
Default My new suspension!
Here's my new suspension. Front and rear adjustable koni's. In the front I'm going to use Eibach Pro-Kit springs (301 lbs/in or 331 lbs/in, does anyone know for sure?) and Ground Control's in the rear (330 lbs/in). Hopefully this will help with understeer. Let me know any comments good or bad.
Old Jun 8, 2004 | 04:13 PM
kamikazeCRX's Avatar
Default Re: My new suspension! (dan4g63)
I've got the Konis...best shocks EVER!
Old Jun 8, 2004 | 04:47 PM
payneth's Avatar
Default Re: My new suspension! (kamikazeCRX)
ooooooh. nice. me want
Old Jun 8, 2004 | 05:20 PM
Smokinsax's Avatar
The Boot
yeah man...how much did you get this setup for?
Old Jun 8, 2004 | 05:32 PM
Outsane's Avatar
interesting to see coil-overs mixed with springs...
Usually guys run stiffer springs in the rear.
Old Jun 8, 2004 | 05:39 PM
SiRex91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamikazeCRX &raquo;</TD></TR><TR><TD CLASS="quote">I've got the Konis...best shocks EVER!</TD></TR></TABLE>
Old Jun 8, 2004 | 06:02 PM
CsRiX's Avatar
Default Re: My new suspension! (SiRex91)
I am running my koni reds and eibach prokit on my 88 CRX si. Loved em for the 1 driving school i got to before my car blew up on the ride home. You will not be dissapointed....
Old Jun 8, 2004 | 06:28 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: My new suspension! (CsRiX)
I,m so jelious.
Old Jun 8, 2004 | 06:30 PM
Sobe_Death's Avatar
Default Re: My new suspension! (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">interesting to see coil-overs mixed with springs...
Usually guys run stiffer springs in the rear.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan4g63 &raquo;</TD></TR><TR><TD CLASS="quote">... In the front I'm going to use Eibach Pro-Kit springs (301 lbs/in or 331 lbs/in, does anyone know for sure?) and Ground Control's in the rear (330 lbs/...</TD></TR></TABLE>
Old Jun 8, 2004 | 06:31 PM
b16_madman's Avatar
Default Re: My new suspension! (LankorDie)
ride must be nice for the $
Old Jun 8, 2004 | 08:15 PM
DC2-JRSC'd's Avatar
Yes that's my goal too. That's why I got the coilovers in the rear. Im pretty sure the pro-kit is 301 lbs/in. This is my first time running koni's, and i hope they will be better then the blistein/tokico combo i was going to use ( which are for sale in the classified section btw )
Old Jun 8, 2004 | 10:52 PM
rice_classic's Avatar
450 up front and 600 in the rear with no front sway bar has my racecar balanced out VERY well. I'd say it's neutral with 5-10% oversteer. I can make it do anything I want.
Some of my competitors are running 600 up front and 900 in the rear.
Old Jun 9, 2004 | 05:25 AM
d16X's Avatar
nice set up
Old Jun 9, 2004 | 07:17 AM
4DRPIMPIN's Avatar
Default Re: My new suspension! (B16_madman)
Interesting setup.
Old Jun 9, 2004 | 08:14 AM
UNDER PRESSURE's Avatar
Default Re: My new suspension! (4DRPIMPIN)
Kool setup. I went with Tokico blue's and ground control coil-overs, pretty good combo IMO.
Old Jun 9, 2004 | 10:21 AM
joesefcivic's Avatar
i guess i just dont understand why he didnt just put he GC'c all the way around. but hey its not me.
Old Jun 9, 2004 | 10:42 AM
DC2-JRSC'd's Avatar
Default Re: (joesefcivic)
Oh I should’ve mentioned this set-up was done on a budget. Everything was around $200.
Old Jun 9, 2004 | 10:44 AM
4drEF's Avatar
Keyboard Humorist
"301 lbs/in or 331 lbs/in, does anyone know for sure?"
What are the numers and stuff written on the springs? You can look them up on web sties to detwrmine what rates they are.
Old Jun 9, 2004 | 10:45 AM
DC2-JRSC'd's Avatar
Default Re: My new suspension! (4drEF)
Yes its 331. I coundnt see the middle number. Does anyone know if ill have any problems running the same rate (330) in the front and rear?
Old Jun 9, 2004 | 11:18 AM
goforbroke's Avatar
MEAT PATTY
You won't have a problem running that spring rate in the front. My daily driver has 400f and 450r and it rotates very easily with the help of the beefy sway bar. But it all depends on what kind of racing your trying to do.
If the car doesn't rotate enough for you turn up the stiffness on the koni's or get a bigger rear sway bar. But don't drive around on full stiff or around that on the street or you will be catching air and getting your shocks revalved faster then you want to.
93egSLEEPER
17
Jun 18, 2007 05:23 PM
efficiencyJunkie
Honda Civic (2001 - 2005)
Jan 2, 2007 10:09 AM
teknohatchie91
Suspension & Brakes
Sep 6, 2005 02:57 PM
mountaindewguy
Suspension & Brakes
Jan 29, 2005 09:14 AM
DC2NR
Sep 11, 2003 02:08 PM
