can you use the endyn breather kit on an LS
seems like everyone i know that has this is ls/vtec or some kind of vtec so just wondering if i can use this on my LS thanks
Yes, it works without issues. The instructions provided call for running the 2 breather lines differently depending on the type of block - other than that the install is the same.
You will have to remove a sensor on the b18a to use the kit (it controls the running of the AC fan after shutdown to cool the engine bay - I am just hardwiring mine to always run).
