Going on to my second Clutch Master Cylinder, WTF??
I lost all pressure in my CMC and saw that it was leaking under the dash so i replaced the master and slave with brand new OEM parts. I bled it and it felt like new. Now today my pedal did THE SAME THING!! Why would it blow again so soon. And this time it isnt leaking inside the car. Any help would be nice~!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">is your clutch pedal adjusted right? what im thinking is that maybe you are pushing the pedal down too much?</TD></TR></TABLE>
yes the pedal is adjusted right, i check that after the first one went
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastVX »</TD></TR><TR><TD CLASS="quote">Did you re-bleed it just to make sure there are no air pockets. Oh and is your slave cylinder leaking?
John</TD></TR></TABLE>
yes i re'bled it and the slave is not leaking
Try and re-bleed it again....sometimes there are air bubbles that get worked down the line over time. Bleed the hell out of it and make sure that is not the problem first!
Is there any loss of fluid in the resevoir? If you see no fluid loss anywhere and the bleeding does not help you might have some bigger issues to deal with. Have a friend move the clutch pedal while you feel and see if the clutch fork is moving at all. If it is moving you may have a dead pressure plate. That could be why you feel no resistance then you press on the clutch pedal.
Good Luck!
John
Good Luck!
John
it looks like the pressure is coming BACK into the resivoir, wouldnt that be an internal leak?>
JimmyAtlantis
Jun 2, 2006 08:55 AM
hip_hop_s0ulchild
Oct 22, 2005 01:35 PM
