wheel stud.
Old Jun 8, 2004 | 12:57 PM
david90's Avatar
Default wheel stud.
I tried to take my lugs off today and one of the wheel studs had tough resistance while the other 3 came out easily. Is it crossthreaded? Is it easy to replace the stud?
Old Jun 8, 2004 | 01:03 PM
The_Todd's Avatar
Farts in the shower
Default Re: wheel stud. (david90)
It could just be stripped or crossthreaded...you can either replace the wheel stud or get it rethreaded.
Old Jun 8, 2004 | 01:13 PM
JDM.Accord's Avatar
Try putting it back on without a wheel on there. Use lots of WD-40 and don't force it if it starts getting tough. If you see metal shavings on the stud or ground, chances are its crossthreading. I had a similar problem but it turned out it was a bad lug nut from a new set I had just purchased.
Old Jun 8, 2004 | 02:32 PM
david90's Avatar
Default Re: wheel stud. (JDMAccord2nr)
My lug is on there right now. I want it off but afriad it might snap. Can I drive with 3 lugs?
Old Jun 8, 2004 | 03:20 PM
tjohnson329's Avatar
chances are it is probaly just well rusted on there. To take it off just use PB blaster. that stuff works great. Just spray it on and let it penetrate then the lug nut should come right off.
Old Jun 8, 2004 | 03:50 PM
david90's Avatar
I read that you could grind off some of the stud's head and it could be inserted into the hub without removing the bearing, anyone did it before?
Modified by david90 at 1:21 AM 6/9/2004
MadVladCivic
Dec 3, 2015 06:50 AM
Eclectia
Jun 16, 2013 11:56 AM
d16skivic
Sep 25, 2008 07:04 AM
drewbie
Welding / Fabrication
Apr 21, 2006 07:28 AM
mingbling
Jul 27, 2004 09:05 PM
