LS/Vtec pistons
Old Jun 8, 2004 | 12:18 PM
93supercoupe's Avatar
Default LS/Vtec pistons
Ok, heres the deal, I have a B18a and i am going LS vtec with a 95 GSR head and B16a1 pistons.When i do the pistonsdo i follow the ring procedure for the b16 or the b18, or does it matter?
And also, what does bump mean?I see it all the time on this sight and have no idea what it means
Slammpig
Old Jun 8, 2004 | 03:58 PM
Rocket's Avatar
Default Re: LS/Vtec pistons (93supercoupe)
B16 pistons will have the same install requirements as b18C pistons.
Bump: means to bring the post to the top again because there is a new post in that thread.
Old Jun 8, 2004 | 06:36 PM
krazie1's Avatar
BANNED
Default Re: LS/Vtec pistons (Rocket)
correct-o mundo Rocket
listen to this man
as his has build a couple him self and knows this junk
Old Jun 8, 2004 | 06:51 PM
LSVTEC0WNZJ00's Avatar
Default Re: LS/Vtec pistons (krazie1)
Get IB Spec Wisecos in the 12:1 C/R range for your motor and do extensive tuning
Old Jun 8, 2004 | 09:29 PM
Default Re: LS/Vtec pistons (LSVTEC0WNZJ00)
but i dont have a b18c, i have a b18a, are those the same procedure as well?
Also, i dont have money for any after market parts, this motor has a 0$ spending limit lol.
Slammpig
Old Jun 9, 2004 | 12:45 AM
ThisLittleSleepeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote"> this motor has a 0$ spending limit lol.
Slammpig</TD></TR></TABLE>
you sure you wanna start this project?
Old Jun 9, 2004 | 02:31 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">but i dont have a b18c, i have a b18a, are those the same procedure as well?
Then don't build it! You should just sell me the head
You need to replace some vital things when doing an ls/vtec: oil pump,water pump, head gasket,timing belt, bearings(should) etc.
Old Jun 9, 2004 | 07:52 PM
Default Re: LS/Vtec pistons (hondaguyef)
Im going to doll that, what i meant by no spending money was for **** like pistons and headwork.Its going to be alstock except for b16 pistons that I already own and new rings, probably OEM.
slammpig
Old Jun 10, 2004 | 09:50 AM
Rocket's Avatar
Default Re: (deZZnuTzZ)
Make sure if the pistons are used and pressed off they will need to be kissed with a hone to make sure the pin bore won't be tight.
silv3rCOUPE
Apr 18, 2009 06:42 PM
CalvitoSol
Aug 26, 2006 02:43 PM
Simple
Aug 16, 2005 10:50 PM
chuckd05
Mar 26, 2003 08:15 AM
DLB1994
May 15, 2002 11:42 AM
