spring rates for skunk workz coilovers/help finding them out
Can some one tell me what the spring rates of these coilovers are. The numbers are front 0700.2.50.008, rear 0700.2.50.006
Thanks
(((btw i tryed to cal them myself with this but i cant seem to figure it out.
"How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length . diameter . spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by".)))
Thanks
96 SOHC VTEC
Mar 30, 2003 07:52 PM
