Running Open Header = Bad?
Old Jun 8, 2004 | 06:27 AM
LudeyKrus's Avatar
Default Running Open Header = Bad?
I just got my Prelude's H23 VTEC running and must drive it for a daily driver; I have college and a job. The problem is that my old exhaust doesn't bolt up. I have a new exhaust on the way, but I have to run open header for about a week. Is there anything major that can go wrong in that time, assuming I baby the car?
I had a neighbor who's builds muscle cars tell me I could warp something.....should I head over to a muffler shop and have them weld me up a cheap shortie turn-down or something?
Old Jun 8, 2004 | 06:35 AM
zad5's Avatar
wut did he say that u can warp. if u run no header at all it could burn a valve but i believe with open header ur good are you going to stick the first o2 bung in or no? i believe u should be ok.
Modified by zad5 at 8:20 AM 6/8/2004
Old Jun 8, 2004 | 06:49 AM
LudeyKrus's Avatar
Let me correct myself: I am running a header w/ the cat installed. The O2 sensor is hooked up. There is still backpressure, it's just that the hot exhaust gasses are shooting out right underneath my car.
He said it could warp the block or oilpan if the gasses shoot out too close to the block.
I am using a 97+ H22 header on my 92 w/ H22, so the header is about 6" shorter than it would normally be, also.
Old Jun 8, 2004 | 07:05 AM
mmuller's Avatar
Mad Scientist
Default Re: (LudeyKrus)
you'll be fine, no burned exhaust valves either, your header is still too long to allow for burned valves.
i've had my exhaust dumping under the car for like a year now
Old Jun 8, 2004 | 07:11 AM
highschooler's Avatar
I am currently running with an open header, and have been for a while now. I really wouldn't worry about anything, except it will probably stink, so dont sit in a garage with your car on, or rev it while you are sitting still.
Old Jun 8, 2004 | 07:22 AM
Ekasey's Avatar
Default Re: (highschooler)
I don't belive your current situation presents anyother problem then being pulled over alot. A turndown would quiet it down and keep the gases off the bottom of the car but thats about it, just wait for your exhaust and you will be fine
Old Jun 8, 2004 | 07:27 AM
LudeyKrus's Avatar
Cool beans, thanks for the info.
Yeah, this thing's about the loudest bitch I've ever heard! And the drone on the highway........ :shoots self in head:
Hopefully I don't get pulled over in the coming week; I'll be staying on the backroads then.
Old Jun 8, 2004 | 08:17 AM
T.J.'s Avatar
Default Re: Running Open Header = Bad? (LudeyKrus)
I ran open header for like 2 months and never had a problem. The only thing negative about it was when i went to work underneath the car later on.
SDT Project EF
Jan 22, 2006 01:34 PM
dohcter g
Sep 11, 2004 10:13 AM
xprohx
Aug 30, 2004 05:48 PM
Irishweird00
19
Feb 4, 2004 06:43 PM
done
Mar 12, 2003 06:03 PM
