Gsr endlinks on Ex LCA w/Si front swaybar
Old Jun 7, 2004 | 10:27 PM
JDM R's Avatar
Default Gsr endlinks on Ex LCA w/Si front swaybar
Anyone know if you can hookup a 99-00 Si front swaybar to 96+ EX lcas using gsr endlinks? i searched and couldnt find anything. Any help is much appreciated.
Old Jun 7, 2004 | 10:55 PM
JDM R's Avatar
Default Re: Gsr endlinks on Ex LCA w/Si front swaybar (JDMar)
anyone?
Old Jun 8, 2004 | 08:54 AM
JDM R's Avatar
Old Jun 8, 2004 | 12:36 PM
JDM R's Avatar
up
Old Jun 8, 2004 | 02:20 PM
JDM R's Avatar
anyone try this?
Old Jun 8, 2004 | 08:47 PM
JDM R's Avatar
up one more time then i give
Old Jun 8, 2004 | 09:28 PM
Knightmare69's Avatar
contact Mr. Choi I believe, he developed some endlinks that allow the Si fron Sway with the factory Ex LCA's.
Old Jun 8, 2004 | 10:08 PM
Mr. Choi's Avatar
New User
yea i tried using gsr endlinks, its possible but only if you remove one of the bushings. check out my thread in my sig. basically made a longer version of gsr endlinks.
Old Jun 8, 2004 | 10:25 PM
JDM R's Avatar
Default Re: Gsr endlinks on Ex LCA w/Si front swaybar (Mr. Choi)
thanks for the info guys. Mr. Choi i checked out your endlinks, how do they hold up? can they take a beating?
Old Jun 8, 2004 | 11:36 PM
Mr. Choi's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMar &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info guys. Mr. Choi i checked out your endlinks, how do they hold up? can they take a beating?</TD></TR></TABLE>
its strong, it held up many mountain passes and one track day at thunder hill.
fyi the bolts are grade 8 and are much bigger than the stock ones. of course they'll take the punishment.
it also comes with poly bushings, a good price for the package vs stock.
i have 440 lb spring in the front with the 26 mm bar. 335 lb rear with 22mm.
more pics on this thread https://honda-tech.com/zerothread?id=873449
Modified by Mr. Choi at 1:23 PM 6/13/2004
JLEK
11
Jun 11, 2007 08:50 AM
SHG_Beans
Suspension & Brakes
Jan 3, 2007 02:22 PM
kodarren
Jun 4, 2006 04:12 PM
whitelightning
Feb 21, 2006 11:15 AM
Solscud007
Dec 9, 2004 03:48 PM
