HI having problems after Swap
Old Jun 7, 2004 | 09:58 PM
Turbocoupe97's Avatar
Default HI having problems after Swap
OK i swapped in my built B16 and it has the STR intake manifold on it, now the motor starts up ok but iddles like ****, and when i go to hit the gas it just wants to die until i come off throttle, and it smells reall rich. Ay ideas? i labaled all teh plugs before taking out stock GSR and put back in same place so cant be the pluggs, could soemhtign be wrong with the head? let me hear some ideas, get back to me thanks
Old Jun 7, 2004 | 10:13 PM
Default Re: HI having problems after Swap (Turbocoupe97)
oh and also, i put new plugs and wires in , and also the IACV is like making a buzzing noise, if someone can help me please i would really appricaite it, thanks
Old Jun 7, 2004 | 10:24 PM
Luserkid's Avatar
Whats the set up? That would help us a little better to help you. Did you get it tuned? More then likely the answers lie there if its a built motor.
Old Jun 7, 2004 | 10:27 PM
Default Re: HI having problems after Swap (Luserkid)
ok its got darton sleeves arais 9:0.1 pistons, Crower Steel rods, blueprinted and balanced crank, portn polishedh ead ferrera valve springs and valves, titaniuim retainers, with stock b16 cams, itsj ust got dc sports headers on it for now with a STR intake manifold, need ot know anyhting else just ask
Old Jun 7, 2004 | 11:30 PM
dantastic's Avatar
sounds like the cam timing is off. check to make sure the cam gears are installed correctly, and that alll the timing marks (crank and cam pullies) are all aligned
Old Jun 7, 2004 | 11:35 PM
Default Re: (dantastic)
the timing was off when i received hte motor i lined the marks up and now timing is back on but, how do you check if the game gears are installed right?
Old Jun 7, 2004 | 11:37 PM
dantastic's Avatar
Default Re: (Turbocoupe97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocoupe97 &raquo;</TD></TR><TR><TD CLASS="quote">the timing was off when i received hte motor i lined the marks up and now timing is back on but, how do you check if the game gears are installed right?</TD></TR></TABLE>
i've personally have never timed gears myself, but i would just assume that you 0 the cams, then set the cam/crankshaft timing
Old Jun 8, 2004 | 12:05 AM
does it sounds liek a timing problem? or could it be maybe some valves are bent possibly? im not fully sure just want to try to fix the problem
Old Jun 8, 2004 | 12:29 AM
any last auggestions what i should do tommorow while working on the motor?
Old Jun 8, 2004 | 10:46 AM
any idea guys?
crookson speed
Engine Management and Tuning
Nov 13, 2017 06:27 AM
stupid fast
11
Mar 25, 2015 07:45 AM
remco
16
Jul 1, 2009 08:16 AM
LSVtechnologytur...
Jul 16, 2005 08:54 AM
sheepey
12
Mar 10, 2005 08:36 PM
