b16 swap question (technical)
Old Jun 7, 2004 | 09:39 PM
fastontheturns's Avatar
Default b16 swap question (technical)
ok im wiring A B16 with a usdm civic harness (92) . question - i see two sensors on the back of the 2nd gen b16 longblock. one i know is a knock sensor. which one ? lower or upper? and what is the other sensor ? oil pressure ? thanks !
Old Jun 8, 2004 | 10:03 AM
bleedblue94's Avatar
Default Re: b16 swap question (fastontheturns)
you are right. the oil pressure is the lower one it is directly next to the oil filter. the knock sensor is closer to the front of the engine (closer to the crank pulley) and a few inches higher
gokus-eg2
May 26, 2012 04:00 PM
wullie_vtec
Feb 3, 2006 02:33 PM
BACKintheDA
Jul 11, 2005 06:04 AM
tegrevboy
Jan 18, 2003 12:05 PM
