LS wiring/ECU question
Old Nov 12, 2001 | 05:10 PM
Overkll's Avatar
Default LS wiring/ECU question
I have a 90 EF HB (Si) with a ZC with an 89 Teg ecu. I am purchasing a 90 LS (complete). What wiring changes have to be made? I hate wiring, so what's easiest? I'll be getting the LS ecu and wiring harness. Should I just use these or the Si harness in the car? I can't seem to find the wiring change answer anywhere on the net. TIA Kerry
[Modified by Overkll, 9:11 PM 11/12/2001]
Old Nov 12, 2001 | 05:23 PM
eg6ajk's Avatar
Default Re: LS wiring/ECU question (Overkll)
you can run that ecu...there will not be a problem...but basically follow the non-obd b16a wiring changes, minus the vtec wires(but then again might as well do that, who know, maybe ls/vtec will come oneday)...
but here: http://b16a.honda-perf.org/wiring.html
and/or http://www.hasport.com/information.htm
[Modified by eg6ajk, 6:24 PM 11/12/2001]
Old Nov 12, 2001 | 07:02 PM
B18b Turbo's Avatar
New User
it will plug right in just use the si wiring harness and the integra ecu youll be straight.plug and play thats it
Old Nov 12, 2001 | 09:29 PM
crxshark's Avatar
New User
Default Re: LS wiring/ECU question (LS CRIX)
yeah, it'll plug right up.
Old Nov 13, 2001 | 07:56 AM
rioninja's Avatar
It will be a tight fit in some spots, but always just use the stock SI harness.
chrysanderson
Mar 24, 2011 05:42 PM
Hybrido_90Civic
Apr 21, 2007 07:20 AM
sik96teg
16
May 26, 2006 11:23 AM
sLoWrAcEr
Mar 2, 2005 05:21 PM
Peter K
Jun 26, 2002 05:44 AM
