Subframe damage???????
Old Jun 7, 2004 | 08:13 PM
mtm584's Avatar
Default Subframe damage???????
I just bought another Eg the other day it is a 1992. It had been hit in the left side bumper was damaged and headlight damaged. It also hit the wheel of the car, the wheel was damaged enough to were a tire could not be mounted to it. When i had came to pick up the car i saw the axle was broke because of all the cv grease underneath the car. So once i get home i pull the axle and put in another one but once i get everything together i noticed that the universal joint boot is not sitting normal. So i check my bolts and the control arms for bends but everything looks ok. So i was thinking the damage my be to the front subframe?
Thanks matt
Old Jun 8, 2004 | 07:23 AM
mtm584's Avatar
Default Re: Subframe damage??????? (mtm584)
Help?
Old Jun 8, 2004 | 07:30 AM
zerogrip's Avatar
Yes, there is a possibility of subframe damage. I replaced mine when I hit a curb which pushed the drivers side wheel back into the wheel well. I just assumed that the subframe needed to be replaced.
Is there any noticible damage to the crossmember/subframe?
Old Jun 8, 2004 | 07:45 AM
mtm584's Avatar
Default Re: Subframe damage??????? (zerogrip)
I have not really paid much attention to the appearence of the subframe unitl this. I guess i will have one of my friends come by and i will compare them. But the control arms look fine so that has to be what it is.
Old Jun 8, 2004 | 07:50 AM
mtm584's Avatar
Does the EG subframe bolt up?
Old Jun 8, 2004 | 07:53 AM
zerogrip's Avatar
It's hard to say but a comparasion of your friends should help. If it is the subframe just pick up another one at a junk yard. I got mine from importautosalvage.com, if you can't find one local get it from there (great cust svc, quick shipping, etc). Good luck.
Old Jun 8, 2004 | 07:55 AM
mtm584's Avatar
Do you live near importautosalvage?
Old Jun 8, 2004 | 07:56 AM
mtm584's Avatar
So it is a bolt in part?
Old Jun 8, 2004 | 08:21 AM
zerogrip's Avatar
No, I don't live near them. They are located in NC.
Yes, the subframe is a bolt on. Does this help?:
Old Jun 8, 2004 | 08:32 AM
mtm584's Avatar
Yea thanks for your help
Old Jun 8, 2004 | 08:37 AM
zerogrip's Avatar
Sure np. I think importautosalvage is in Marion, NC which should be only 30min away from Morgantown. You could just stop by and pick one up.
mimog3
Sep 18, 2012 03:44 PM
RomesEM1
Suspension & Brakes
Aug 24, 2009 02:02 PM
all_conference
16
Jul 1, 2009 11:06 PM
ryanstev
Suspension & Brakes
Nov 13, 2007 05:24 AM
ITRDC2R
Jun 1, 2007 05:43 AM
