RPM when starting car
Old Jun 7, 2004 | 07:42 PM
Pilchard's Avatar
Default RPM when starting car
When I start my car (1991 Accord, automatic) the rpm jumps up to about 2000 but as soon as it's started (within a couple seconds) it jumps down to about 1000 (warm weather).
I've never seen that in a car; any other car I've driven the rpm goes up and just stays there without coming down extremely quickly like that.
Does anyone know why this would be happening?
Thanks in advance!
Old Jun 7, 2004 | 08:00 PM
hondadude's Avatar
Default Re: RPM when starting car (Pilchard)
Too much air... Check for vacum leaks...should be some slack in throttle cable..Fast idle valve may need screwed in a couple turns. The base idle should really be lower than 1000??
Old Jun 7, 2004 | 10:37 PM
IVI's Avatar
IVI
Default Re: RPM when starting car (hondadude)
vaccum leaks would be consistent.
i think its just your car is cold, even tho its warm weather, which is why it does it for a very short amount of time.
are you getting any cel ?
any other symptoms ?
Old Jun 8, 2004 | 04:30 AM
Mike813's Avatar
from what ive read, most 4th gens are steady at 1k-1.5k usually, my 5th gen use to idle up to 2500 every cold startup, but after 2 cans of tb cleaner, its been idling at 2000-1800k area, pretty normal for a 130-140k car i would say...
josh devera
Jan 9, 2018 04:38 AM
Apple395
Aug 16, 2013 10:13 PM
lxuxrxcxh
Classic Hondas
Aug 23, 2007 12:26 PM
ILOVEGIRLS
Sep 2, 2003 06:54 AM
