bov chatter, or is it compressor surge?
Old Jun 7, 2004 | 06:51 PM
b16ahybrid's Avatar
Default bov chatter, or is it compressor surge?
Over the past weekend I replaced my intercooler with a larger one along with the piping.
I used to have a 3'' 90 degree elbow coming off my turbo with the filter on the end. Well the way the new piping is ran i cant run my intake like that anymore so I have the filter just clamped onto the turbo. the problem is that my bov now sounds like it chatters when it goes off.
I know it's not because of the piping or intercooler because it did this before (thats why I installed the intake)..
Why would my bov chatter when I have no filter or just the filter attached to the turbo with no piping between?
It did this with my old bov (saab) and my new one. Is it something I should worrry about? Look into?
Old Jun 7, 2004 | 07:03 PM
SiRkid's Avatar
Default Re: bov chatter, or is it compressor surge? (b16ahybrid)
what bov?
is it too tight?
vacuum source not strong enough?
i know i have comp surge with the shitty max rev bov im using.
Old Jun 7, 2004 | 07:51 PM
Pengo's Avatar
sounds like bov is either adjusted improperly or bad/leaking vac source
Old Jun 7, 2004 | 08:34 PM
b16ahybrid's Avatar
Default Re: bov chatter, or is it compressor surge? (Pengo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo &raquo;</TD></TR><TR><TD CLASS="quote">sounds like bov is either adjusted improperly or bad/leaking vac source</TD></TR></TABLE>
So why would it do it only when I have no intake? It's fine when I have a intake hooked up.
Old Jun 7, 2004 | 08:37 PM
b16ahybrid's Avatar
Default Re: bov chatter, or is it compressor surge? (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">what bov?
is it too tight?
i know i have comp surge with the shitty max rev bov im using. </TD></TR></TABLE>
megan racing bov
It did this with my bosch bov too, so I know it's not the bov. I even adjusted it with no avail.
Vacuum source comes strait from the pcv valve so I know it's good.
Old Jun 7, 2004 | 09:05 PM
BodyKits NW's Avatar
I've used the Max-Rev BOV with no problems. Are you sure its adjusted properly.
Old Jun 7, 2004 | 09:20 PM
b16ahybrid's Avatar
Default Re: bov chatter, or is it compressor surge? (BodyKits NW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">I've used the Max-Rev BOV with no problems. Are you sure its adjusted properly. </TD></TR></TABLE>
YES.
I had this same problem with a different non-adjustable bov.
Works fine with 10'' intake pre turbo, makes chatter sound when I remove that piping and run a filter only or even with no filter.
This bov I'm using now, is adjusted correctly because it chattered when I first put it on, I adjusted it and the chatter went away. It has ran fine since then. That is until I remove that section of piping.
it's not the bov, nor is it the vacuum source. Thats why I'm baffled, both of those items have been addressed.
hondaeg8
Texas -OK -LA (Sales)
Aug 9, 2009 07:18 PM
Mr HYDE
Aug 30, 2006 05:09 PM
buttsneeze
Mar 17, 2005 11:07 PM
Snail EK
Jan 12, 2005 09:41 PM
civbeater90
Sep 2, 2002 12:39 AM
