ECU Swap..????????????
im not to smart on ecu things so, can you take a stock 91 CRX ECU and swap the plugs with a 92 GSR to run a 93 2.1 Stroker LS Integra? I need help quick, Hot Import Nights is in 6 days!!!!!!!!!!!!
the only way to run an obd 1 92-95 ecu is if you were to run an obd0-1 conversion harness. contact blown90hatch if you want that harness so you can run an obd 1 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B21A1Stroker »</TD></TR><TR><TD CLASS="quote">Hot Import Nights is in 6 days!!!!!!!!!!!!</TD></TR></TABLE>
from what I remember you only see cars there
they dont even turn on the showcars..
and yes this thread is worthless without pics...
