Can someone help?
Old Jun 7, 2004 | 03:39 PM
icedoutteg's Avatar
Default Can someone help?
I have a 94 integra (B18b1) that I replaced the tps in it. But now it is acting strange. It has a high idel. Which I can not seem to fix and it is now not put forth as much power. Sometimes when I shift it does not pick it up when I do it. I am not sure what to do beside re set my ecu. But I am not sure how to do that. Any advice would be great
Old Jun 7, 2004 | 04:16 PM
Axle's Avatar
Try adjusting the idle air screw to where you want the idle to be.
Old Jun 7, 2004 | 04:20 PM
G1 TEGGY's Avatar
Default Re: (Axle)
resetting the ECU is nothing more than unplugging the negative battery cable for a few minutes.. go ahead and reset the position of the Idle Air Screw to make sure it's set right, turn it inwards until the car starts to stall then back it out at 1/4-turn intervals til it's at about 750 RPMs, or if you have a timing light you can set it by that.
bk7794
20
Aug 7, 2016 02:59 PM
werteg
Jun 3, 2012 07:25 AM
JasonST
Jun 30, 2006 11:22 AM
fowler!
Sep 21, 2002 01:50 PM
