WTF trunk leaking. again.
Yea, well i never had much problems with my crx leaking.
i have new roof liners with silcione under neath, and silconed up my tail lights and stuff. it rarly ever, never leaked.
well down OC,Md this weekend and i went to open up my rear cover where the spare is, i keep a towel in there for whatever reason and a shammie.
well the entire thing was basically drenched. the towel was probably. 5 lbs heavy. no lie. when i looked around, i saw water coming in from those little vents in the cargo area on the sides. any help? thanks!
ever check the rear sunroof drains? you have to take the rear bumper off but there is 1 per side. You'll see an end of the rubber hose sticking out under each corner of the tail lamp. one of mine have sludge built up in and it backed up and leaked water in from the left corner exactly where you are describing.
Hey mine does the same thing, here is a link, maybe this will help? I found out where mine was leaking at the top but mine is leaking somewhere else cuz i still have a little bit of water in the spare tire place.
http://www.jdmuniverse.com/for...25244
