help a newbie build a single cam..
Old Jun 7, 2004 | 02:51 PM
JdmSpoonEg's Avatar
Default help a newbie build a single cam..
hey guys im new here..hope to increase my knowledge...anyways heres the thing im intrested in building up my d16 just the basic eg si motor.. but i wouldnt no where to start? this week im gettin my ecu chipped to improve little things here and there but nothing that special. My motor is completely stock with just a basic short ram intake. Im located in toronto, canada and just not sure parts are good and what is the correct way? inform a newb :D
by the way heres a pic of my car..
Old Jun 7, 2004 | 02:53 PM
jcarothers's Avatar
nie car... and nice color.
just do bolt ons and work your way inward.. also, waht kind of power are you looking for?
Old Jun 7, 2004 | 02:54 PM
JdmSpoonEg's Avatar
Default Re: (jcarothers)
leaning more towards all motor..
Old Jun 7, 2004 | 02:58 PM
JDM EJ1 95's Avatar
well for the money it is going to take for the D to be as fast as a B.. you could swap it
Old Jun 7, 2004 | 03:00 PM
JdmSpoonEg's Avatar
Default Re: (JDM EJ1 95)
thats the most obvious route to take but i wanna try building this up..
Old Jun 7, 2004 | 03:01 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: help a newbie build a single cam.. (JdmSpoonEg)
Well you can complete the basic bolt-on's.
A Bisi header would be a nice start as well as a 2.5" exhaust. Ported t/b and a ported intake manifold or aftermarket replacement is a good start. Proper tuning device and fuel set-up (i.e. OEM DOHC or Walboro pump if needed, Injectors etc..) It all depends on how extensive you want to go. Just saying you want to "stay all motor" can leave it up in the air.
You can do a basic engine rebuild with OEM pistons to the compression of your choise as there are quite a few choices available. Or you can have the block resleeved, overbored and do forged internals.
As far as the head goes port and polish, upgraded valvetrain and the cam of your choice to match your compression and overall goals with the motor. Skunk2, ZEX and Exospeed offer some nice street cams. Crower offers quite a choice of cams to suit your needs from mild to wild.
These are just some run of the mill things to get you started. Hang out and do some searching around. Trust me there are LOTS of articles are D-Series performance.
Old Jun 7, 2004 | 03:05 PM
Dacalac's Avatar
Default Re: help a newbie build a single cam.. (Mr Milano)
read this:
https://honda-tech.com/zerothread?id=335078
17 pages of good stuff!
and check the link archive at the top of the forum.
Old Jun 7, 2004 | 03:06 PM
JdmSpoonEg's Avatar
bisi ? Bisimoto Engineering ?
Old Jun 7, 2004 | 03:11 PM
tolowhb's Avatar
Boost it!
Old Jun 7, 2004 | 03:13 PM
civic duty's Avatar
Here are two forums i frequent
http://www.d-series.org
http://www.sohchonda.com
Old Jun 7, 2004 | 03:15 PM
frostcivic's Avatar
"well for the money it is going to take for the D to be as fast as a B.. you could swap it"
don't listen to fools like this, you won't learn anything about engines if you listen to hicks like this.
The Internet Tough Guy's Avatar
Default Re: (frostcivic)
https://honda-tech.com/zerothread?id=385741
Old Jun 7, 2004 | 03:25 PM
thenick's Avatar
Default Re: (jwn7)
is that an ABS spoon lip?
to answer your question, i would boost. i have 25psi capable pistons and rings for $110, if you score some LS rods for cheap and machine them to fit and buy the bushing's it'll set you back like $100, that's boosting 15psi on stock sleeves
as for as an N/A D goes i feel about it
Old Jun 7, 2004 | 03:32 PM
Deemeetree's Avatar
Electrician
If you just want a semi-quick car to get around just do a mild build.
Higher compression pistons
Stronger connecting rods
Head work with porting
Milder camshaft
Header
Intake
Upgrade the intake manifold (JG)
Chip
Should get you around town fairly quick. If you want to go around town really fast...definitely need to turbo it.
Old Jun 7, 2004 | 03:37 PM
Dacalac's Avatar
Default Re: (Dimi)
just saw a pic of the Bisi header:
interesting to say the least!
Old Jun 7, 2004 | 04:00 PM
RC_SKUBY's Avatar
nice car man. as for your question youd be a lot better off boosting then going all motor. it wouldnt be worth all the money on the D series(imo). Youll be quite satisfied with a boosted D for a while. till you save up enough for a swap
Old Jun 7, 2004 | 04:03 PM
filthyCREX's Avatar
Default Re: (Dirk Lance)
what kind of number are attached to that header?
any dyno charts?
BTW.. nice looking car!!!!
Old Jun 7, 2004 | 04:26 PM
slowhatch4now's Avatar
Default Re: help a newbie build a single cam.. (skuby_do)
nice *** car dude, where did u get that lip? wana sell it?
PeaCE
Old Jun 7, 2004 | 04:31 PM
alloutmotor's Avatar
d-series huh, i think u should boost it
Old Jun 7, 2004 | 05:13 PM
CivicVX94's Avatar
Default Re: (thenick)
hey man fill me in on those pistons and rings
Old Jun 7, 2004 | 05:14 PM
ej1 pilot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostcivic &raquo;</TD></TR><TR><TD CLASS="quote">
don't listen to fools like this, you won't learn anything about engines if you listen to hicks like this.</TD></TR></TABLE>
end your life
Old Jun 7, 2004 | 05:21 PM
Tad's Avatar
Tad
mill the head get a good cam,
skunk2 intake manifold,
and tuning.
you should be able to put down over 130 whp easy.
Old Jun 7, 2004 | 05:27 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
nice car for a beginner
Old Jun 7, 2004 | 05:40 PM
Jokerluv's Avatar
sweet ride
Old Jun 7, 2004 | 05:41 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote">well for the money it is going to take for the D to be as fast as a B.. you could swap it</TD></TR></TABLE>
TRUE DAT.
i was trying to build my D.... but the amount of money and time, i could have a B in there.
so, i quit with the D and am leaning towards the B after i finish this suspension/brake upgrade.
even though it was nice to say, " SOHC "
COMPRESSION...... pistons, milling, or thin head gasket.... get that up, and it'll pull some decent power. thats a start.
