Idle bounce after a/c shuts off??
ive done the search and most peoples problems begin at warm up only.
My car's idle bogs up and down after ive had my A/C on and when my gears in Park, if its in drive with a/c on the car shakes like no tomorrow like im on a bus or something and idle sticks at 1k... anyone had this problem?? only happens after A/C's been on, otherwise its perfectly normal... any help would be appreciated thanks.
My car did that when I had just put on my intake (like 2-3 years ago) and found out some of the lines weren't hooked up causing a vacuum leak. This "problem" actually caused my AT to go out
After I installed my intake correctly there are no problems :shrugs:
yeah dude i have the same problem on my 94 accord ex when the ac is on the car seems like it has half the power it normally does and the car shakes some..... it pisses me off so bad i just wind the windows down and sweat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by groove control »</TD></TR><TR><TD CLASS="quote">What year is the car Mike813?Are you throwing any codes?Sounds like a vacuum leak.</TD></TR></TABLE>
oh my problem went away already... someone just brought the thread back up..
but i dont exactly know what i did to get it working but i did get my timing adjusted, cleaned out TB butterfly, adjusted the tb cable, cleaned iac and it went away for me.
trooper0641
May 10, 2006 03:28 PM
homeskillet
Jan 13, 2005 05:04 PM
