obd0 b16 in a 96 EK, few obd questions
I hear the DX wiring harness will plug into the b16 but, of course, I will have to run the VTEC wires. I am planning on getting an OBD 2 - 1 jumper and running an obd 1 p30. My question is, besides the dist., what esle do I need to change to obd 1? Also, will an obd 1 engine engine plug into an obd 2 car? thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c3 »</TD></TR><TR><TD CLASS="quote">I hear the DX wiring harness will plug into the b16 but, of course, I will have to run the VTEC wires. I am planning on getting an OBD 2 - 1 jumper and running an obd 1 p30. My question is, besides the dist., what esle do I need to change to obd 1? Also, will an obd 1 engine engine plug into an obd 2 car? thanks for the help.
Im going to assume your car is already obd-2. Since you will getting a ecu conversion obd-2 to obd-1 harness, then the stock engine bay harness will be fine. you will not have to convert anything else. just plug up the jumper and you should be fine. Not for sure if the dizzy needs to be changed, but i could be wrong. I think the dx dizzy plug should plug up to the ctec dizzy plug if its the same obd.
</TD></TR></TABLE>Im going to assume your car is already obd-2. Since you will getting a ecu conversion obd-2 to obd-1 harness, then the stock engine bay harness will be fine. you will not have to convert anything else. just plug up the jumper and you should be fine. Not for sure if the dizzy needs to be changed, but i could be wrong. I think the dx dizzy plug should plug up to the ctec dizzy plug if its the same obd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greasemonkey »</TD></TR><TR><TD CLASS="quote">EX wiring harness will work best</TD></TR></TABLE>
because it has the vtec wiring already inside. good point.
Modified by fasthatch89 at 10:43 PM 6/7/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c3 »</TD></TR><TR><TD CLASS="quote">im pretty sure i will need a obd 1 vtec dizzy...can anyone confirm it though?</TD></TR></TABLE>
Nope, it will work the same as a OBD1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch89 »</TD></TR><TR><TD CLASS="quote">
I think the dx dizzy plug should plug up to the vtec dizzy plug if its the same obd.</TD></TR></TABLE>
ah yes, but it is not the same obd. im putting a obd0 first gen b16 in the obd2 civic. so basically i will need an obd1 vtec dizzy if running an obd1 ecu
ah yes, but it is not the same obd. im putting a obd0 first gen b16 in the obd2 civic. so basically i will need an obd1 vtec dizzy if running an obd1 ecu </TD></TR></TABLE>
Or OBD2 dizzy
Or OBD2 dizzy
SPOON_BeIgHtEeNsEe
Aug 2, 2006 10:28 AM
Unsivil_audio
Oct 26, 2004 02:59 PM
