should i change the evaporator if im chaning a A/C compressor?
Old Jun 7, 2004 | 09:06 AM
Used2beAb16's Avatar
Default should i change the evaporator if im chaning a A/C compressor?
I just changed the a/c compressor on a car here, the compressor was locked up, should i change the evaporator aswell? Or will the compressor get fucked up again from metal?
thanks
Old Jun 7, 2004 | 11:12 AM
rogue3221's Avatar
Default Re: should i change the evaporator if im chaning a A/C compressor? (Used2beAb16)
depending on the damage, most of the bigger pieces may have gotten caught inside the expansion valve which might have to be replaced or at least inspected so you could have gotten lucky. I would also consider replacing the receiver/dryer as it may have collected the smaller particles. A thorough job would be to flush the evaporator and condensor but I don't know if they offer that anymore??
Old Jun 7, 2004 | 11:46 AM
Default Re: should i change the evaporator if im chaning a A/C compressor? (rogue3221)
thank you, you reccomend replacing the expansion valve and the dryer.
Old Jun 9, 2004 | 08:19 AM
4door-r's Avatar
take that A/C out an roll your window down.
baybay
Aug 26, 2018 02:39 PM
islandgurl305
Jul 21, 2017 07:07 AM
carguy10
Honda CR-V & Element
Jun 15, 2015 08:31 AM
Rick1t
May 9, 2013 04:49 AM
jasrams
Honda Civic (2001 - 2005)
Apr 23, 2012 08:59 AM
