stock cpmpression ls vtec?
Old Jun 7, 2004 | 07:32 AM
tray3rd's Avatar
Default stock cpmpression ls vtec?
what would be stock compression for an ls vtec? i want to go 11:1 but people say i wont be able to run pump gas is this true or what? if so how high can i go and still run pump gas?
Old Jun 7, 2004 | 12:39 PM
nub's Avatar
nub
Default Re: stock cpmpression ls vtec? (tray3rd)
assuming you used a head from a b16 and an oe headgasket you should be right at 9.5:1 the easiest way to bump to your target comp would be oe b16 (us) pistons that would put you at 11.3:1 with an oe headgasket. as far as using pump gas it depends on what is available in your area octane wise
projectef
Jun 13, 2007 02:46 PM
tomu06
Mar 30, 2006 03:07 PM
94si94cx
Oct 1, 2002 07:20 PM
EVOCELICA
Jul 9, 2001 04:34 PM
