Swapping cranks??????
Old Jun 7, 2004 | 06:46 AM
EGJDM's Avatar
Default Swapping cranks??????
Hey I was wondering what is the best way about swapping a ls crank from one block to another?
Old Jun 7, 2004 | 07:52 AM
EGJDM's Avatar
Default Re: Swapping cranks?????? (EGJDM)
BUMP!!!!!!
Old Jun 7, 2004 | 08:06 AM
b18cx's Avatar
tear it down, check everything out (spec) get new bearings and rings, ect......., reassemble it.
Old Jun 7, 2004 | 09:09 AM
JDMotive's Avatar
Default Re: Swapping cranks?????? (b18cx)
yea...just pull it from one block,get new bearings and piston rings and swap into another block.
Old Jun 7, 2004 | 09:13 AM
EGJDM's Avatar
Default Re: Swapping cranks?????? (JDMotive)
thanks guys I was worried that it might have to be line bored.
Old Jun 7, 2004 | 09:36 AM
JDMotive's Avatar
you only have to line bore it when you swap the caps from another block.
Old Jun 7, 2004 | 09:42 AM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">you only have to line bore it when you swap the caps from another block.</TD></TR></TABLE>
Or if the block gets warped.
Old Jun 7, 2004 | 10:24 AM
EGJDM's Avatar
Default Re: Swapping cranks?????? (LudeyKrus)
Thats great thanks guys for your help!!!!!!!
boomer411
10
Dec 23, 2017 04:38 AM
BILLETGRIP
Apr 13, 2007 10:34 AM
MAPU
Mar 4, 2006 09:51 PM
EGJDM
Aug 17, 2004 07:28 PM
Bnjmn
Jul 4, 2003 04:27 PM
