FS/FT Indiana 88crx W/Built b20Vtec Tein Recaro JE Skunk2 Much more!
Car is a 88 crx si. Motor has under 500 miles on all parts! The rest of the parts have under 1500 miles on them. Body work is done and car is ready for paint. There are no problems at ALL with anything on the car or engine, I have started to lose interest in the project. Everything on the car works including the sunroof.I am open to trades but it must have a swap and be a reasonable trade. Now on to the goodies....
JG cam sprockets
B20b bottom fully balanced, darton sleeves
Eagle rods balanced
JE 12.5 85mm pistons rolled, balanced, polished
Micropolished and nickleplated journals and lightned crank
Msd 6al with Blaster SS coil
Vtec oil pump
Vtec water pump
B16A tranny with quaife LSD
Place racing axles
3 ADR motor mounts, and one front place racing mount
Skunk2 intake Manifold port matched to throttle body
BBK 70 mm throttle body
Skunk2 dual valve springs
skunk2 retainers
Skunk2 stage 2 cams
skunk2 valves
3 angle valve job
Mild race port and polish
Full size Fluidyne
AEM Fuel rail
Aem fuel pressure regulator
DC header with a RTC 3in collector
3in cat back exhaust
-6an fuel hoses in and out with a 8 gallon fuel cell
ACT Xtreme pressure plate
Clutch masters stage 4 disc (4 puck) BRAND NEW
Vis Carbon fiber hood
Wings west front bumber
Suspension technics sway bars
Polyurethene bushing all around
Tein HA's Coilovers
Powerstop front rotors
Goodridge Brake lines front and back
AEM brake pads
Autotech 6 bar rollcage
Recaro millenium seats VERY RARE SEATS!!
Summit battery box
Optima battery
Neuspeed front strut bar
Topspeed back strut bar
DC lower rear tie bar
Act Prolite flywheel BRAND NEW
Place Racing front traction bar
ACL Main rod bearings along with thrust bearings BRAND NEW
Moroso Breather setup
AEM intake
Pictures can be seen here...http://home.comcast.net/~bleighton/
The body is all back together now and just needs the sides and rear of the wings west kit to complete the exterior. Vin will be furnished to serious buyers or mods upon request
Modified by FrankensteinCRX at 5:44 AM 6/7/2004
JG cam sprockets
Eagle rods balanced
Vtec oil pump
Vtec water pump
Place racing axles
skunk2 retainers
Skunk2 stage 2 cams
skunk2 valves
3 angle valve job
Full size Fluidyne
AEM Fuel rail
Tein HA's Coilovers
AEM brake pads
Summit battery box
Optima battery
AEM intake
TREESnoseeds787
Nov 1, 2008 08:31 PM
