Bumpstops
Old Jun 6, 2004 | 10:07 PM
ultimatehonda's Avatar
Default Bumpstops
I just bought some tokico illuminas...They came with bumpstops in for the rears but none for the front. Should I use the ones it came with for the back and just use the oem front bumpstops? Also I am lowered on H&R sports....should I trim the bumpstops at all?
TIA
Old Jun 7, 2004 | 12:35 AM
Z6BOOSTIN_Y0's Avatar
Default Re: Bumpstops (ultimatehonda)
IMO i would leave it alone or your shock's life will be shorten or ruined
Old Jun 7, 2004 | 05:38 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda &raquo;</TD></TR><TR><TD CLASS="quote">
TIA</TD></TR></TABLE>
Yes you should. The H&R's should have come with a diagram showing how much to trim. It's basically 1/2 the bumpstop, and use the top half (the wider section) to put onto the shocks.
Old Jun 7, 2004 | 08:36 AM
Default Re: Bumpstops (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
Yes you should. The H&R's should have come with a diagram showing how much to trim. It's basically 1/2 the bumpstop, and use the top half (the wider section) to put onto the shocks.</TD></TR></TABLE>
Well my springs are sports, and it said not to cut them at all, but I read that everyone trims them??
Old Jun 7, 2004 | 09:46 AM
LudeyKrus's Avatar
Use your OEM bumpstops on the front shocks. Cut them in half.
If you don't cut them and you lower your car, you will be bottoming out much more often.
Old Jun 7, 2004 | 11:39 AM
kamikazeCRX's Avatar
Default Re: (LudeyKrus)
I put H&R race on my car with Koni yellows...i'm having a hard time remembering if i cut my bump stops...for some reason i don't think i did.
But i don't bottom out really, not even in hard turns during autocross
Old Jun 7, 2004 | 08:19 PM
Well I just finished installing the shocks and I did cut the bumpstops in the front.
AlphaQup
Suspension & Brakes
Jun 22, 2008 05:51 PM
DC2 to AP2
Honda S2000
Mar 3, 2006 08:33 PM
bottlefed13
Suspension & Brakes
Jul 31, 2005 08:56 AM
spddmn124
May 21, 2005 03:07 PM
eg686
31
Jul 23, 2003 09:50 PM
