Transmissions are swapped! Just one small problem
Old Jun 6, 2004 | 08:57 PM
drewbie's Avatar
Default Transmissions are swapped! Just one small problem
CX to Si tranny is complete. No cels!!
The only problem I have is that I cant get the axles all the way into the tranny.
Are you supposed to hammer them in?
How do you get them all the way into the tranny?
Old Jun 6, 2004 | 09:00 PM
DJ_SaNdOz's Avatar
Default Re: Transmissions are swapped! Just one small problem (Mr. Teal)
are you using the correct axles for the application? I've never had to force axles in, they always slide right in........
boostng r's Avatar
a
rubber hammer its hella easy i use my hands
Old Jun 6, 2004 | 09:08 PM
drewbie's Avatar
Default Re: Transmissions are swapped! Just one small problem (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">are you using the correct axles for the application? I've never had to force axles in, they always slide right in........</TD></TR></TABLE>
of course Im using the right axles.....But they arnt going all the ay in!
I dont know why.
they will however go far enough in to turn the gears. You can turn one axle and the other will turn the other way.
But they just arnt getting flush against the houseing. The right side axle wont even come within an inch of the houseing. (the big part that is brown (on the axle))
Old Jun 6, 2004 | 09:14 PM
ABK's Avatar
ABK
what you do is put the axle in, have some one hold the knucle out the way and try to push (from the end) having the axle pointing up slightly. That way you can put your weight on it and it should snap on (you will have to wigle it a little bit).
Old Jun 6, 2004 | 10:04 PM
The Internet Tough Guy's Avatar
Default Re: Transmissions are swapped! Just one small problem (ABK)
make sure you grease those splines up real good first.
then they should just 'pop' right in
cehcivic15
13
Sep 4, 2008 11:19 AM
1bar_ek
May 18, 2008 04:44 PM
SimplyTron
Dec 6, 2005 05:50 PM
hellogoodbye
Apr 5, 2004 04:11 PM
MugenGTR
Jul 24, 2002 08:43 AM
