is my radiator working or not?
Old Jun 6, 2004 | 08:29 PM
gobblebox59's Avatar
Default is my radiator working or not?
Hey I have a 1999 civic si, my coolant tank has not much fluid in it but my resivour is full.. i turned my car on and the coolant tank doesn't get any more full or anything like im pretty sure its supposed to so idk, i need help sorry :\ thx
my short shifter started getting really hot too, im not sure what that is either...
Old Jun 6, 2004 | 08:34 PM
Luserkid's Avatar
Default Re: is my radiator working or not? (gobblebox59)
Dont forget that your coolant circulates throughout the engine. So one time you look at it it might be half and then another time itll be full. So maybe thats whats going on.
Also the short shifter problem.... look on your other thread.
Old Jun 6, 2004 | 09:13 PM
IVI's Avatar
IVI
radiator systems work with pressure.
there is really no way for a radiator to work or not work. the sole purpose of a radiator is to cool the coolant. the only thing that cant 'work' is the radiator not cool correctly... due to leaks, lack of pressure. or clogged radiator, fluid cant flow properly and get cooled.
to check if its clogged feel the top hose, then the bottom hose, both should be hot. is the only reason you think its not working becuase of your overflow bucket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gobblebox59 &raquo;</TD></TR><TR><TD CLASS="quote"> my coolant tank has not much fluid in it but my resivour is full.. </TD></TR></TABLE>
by coolant tank do you mean radiator? and if so how did you check how much fluid in the radiator? it should be filled ot the top. when are you checking? more details please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gobblebox59 &raquo;</TD></TR><TR><TD CLASS="quote"> my short shifter started getting really hot too, im not sure what that is either...</TD></TR></TABLE>
thats probably because its right under your exhaust.
Soooogie
Sep 29, 2013 04:54 AM
slikz714
Jul 12, 2006 03:40 AM
B6tPoweredMx3
Dec 10, 2005 03:52 PM
kingpen
Sep 25, 2002 01:11 PM
4doorH22
18
Jan 19, 2002 01:06 PM
