D series hydro tranny. Mount and axle questions. Don't tell me it's a waste...
Besides the obvious stuff like possible firewall flex, getting the clutch MC hooked up, and the proper pedal assembly....is there anything preventing the install of a D series transmission?
Things like the tranny mount, and if you can reuse the stock axles etc.
I don't want to start a cable vs. hydro war, or have a huge debate...I'd just like to know about these two things. TIA.
if you are changing from cable to hydro or vice verse I would think the axles would be different.
make sure the clutch is aligned.
make sure the input shaft matches the clutch you are using...
all I can think of now, its late.
BTW: you thread is worded poorly so I apologize in advance if I didnt answer your question.
As far as I know, it won't bolt in without custom fabrication of mounts. This is why nobody does it.
BriantheButcher
Jan 16, 2009 03:48 PM
95 vtec
Nov 14, 2006 08:35 PM
JDM Like Whoa
Oct 20, 2006 08:16 AM
