Shift Rod removal. need help
Old Jun 6, 2004 | 04:30 PM
typeeg's Avatar
Default Shift Rod removal. need help
I'm attempting to remove the shift rod out of my j1 tranny. I notice a small roll pin under a c-clip which keeps the shift rod in place. I tried using a bolt that was same size as the pin and hammer but it wouldn't even budge. It is kind of hard for me to get any leverage since I'm under the car also. WOuld it be possible for me to disassemble the shift rod from the shifter and then pull the whole thing out or would that require additonal steps? ANy insight is appreciated.
Old Jun 6, 2004 | 06:08 PM
mmuller's Avatar
Mad Scientist
Default Re: Shift Rod removal. need help (StockEG9)
hehe the infamous bitch pin....
you need a punch or you can use one of the AC compressor bolts.
Old Jun 6, 2004 | 08:50 PM
pgpunkguy's Avatar
Default Re: Shift Rod removal. need help (mmuller)
punch
Old Jun 6, 2004 | 08:56 PM
Whitfield Inc.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">hehe the infamous bitch pin....
you need a punch or you can use one of the AC compressor bolts.</TD></TR></TABLE>
Taht is what we used for years at the shop - the small point on the end of the bolt helps to align it. And the size goes thru the hole perfect, we have recently changed to an air hammer and that is the best tool ever
Old Jun 7, 2004 | 07:32 AM
typeeg's Avatar
Default Re: Shift Rod removal. need help (RageDzine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine &raquo;</TD></TR><TR><TD CLASS="quote">
Taht is what we used for years at the shop - the small point on the end of the bolt helps to align it. And the size goes thru the hole perfect, we have recently changed to an air hammer and that is the best tool ever </TD></TR></TABLE>
Well could i just remove the shaft itself by detatching the rod from the shifter under the car? Will it slide out or no?
Old Jun 7, 2004 | 08:54 AM
acy76's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 &raquo;</TD></TR><TR><TD CLASS="quote">Well could i just remove the shaft itself by detatching the rod from the shifter under the car? Will it slide out or no?</TD></TR></TABLE>
The shift rod won't come out of the transmission without opening it up and taking the selector mechanism apart. Your best bet is to get the pin out.
Try raising the car up higher on stands to get some swinging room, use the right punch, and a heavy hammer. Soak it with PB Blaster or similar first.
Old Jun 7, 2004 | 09:59 AM
APEX CRX's Avatar
Default Re: Shift Rod removal. need help (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">
Try raising the car up higher on stands to get some swinging room, use the right punch, and a heavy hammer. Soak it with PB Blaster or similar first.</TD></TR></TABLE>
use a 8mm punch and a big hammer
Old Jun 7, 2004 | 10:44 AM
IN VTEC's Avatar
I use a rolled pin punch. It's got a little **** on the end that centers into the pin. $20 from Sears for a set.
If your computer can't handle 100+ 640x480 pics, then don't click on it.
https://honda-tech.com/zerothread?id=795700
DexterII
Mar 19, 2015 02:22 PM
BukakkEK9
Jun 6, 2007 07:05 AM
gursh d
27
Jun 2, 2007 07:18 AM
mymeatb18"
Oct 30, 2005 10:35 PM
dynomax27
Aug 23, 2003 01:57 PM
