91 Civic Sedan water leak
Old Jun 6, 2004 | 04:30 PM
Pedro02093's Avatar
Default 91 Civic Sedan water leak
Looking for advise on the fix for a water leak that comes in up under the dash on the left side.
Old Jun 7, 2004 | 12:39 PM
dr_latino999's Avatar
Default Re: 91 Civic Sedan water leak (Pedro02093)
Around your feet or on the actual guage cluster?
Old Jun 7, 2004 | 01:50 PM
Pedro02093's Avatar
Default Re: 91 Civic Sedan water leak (dr_latino999)
not in the dashboard..it comes in way up in the upper left corner(if you stuck your left foot up under the dash .that's where) and runs down the side. I am thinking it's where the firewall seam is..but I'm not sure how to get at it to silicone it.
Old Jun 7, 2004 | 03:23 PM
The sources of the leak that I can think of that I have had:
Check to make sure the radio antenna rubber gasket is solid, or water will drip right down the frame and end up over the clutch pedal. Also, check all your fire wall grommets, any spots where cables pass through and make sure that the grommet is A) in good condition and B)still there. I removed my cruise control and still have yet to fill in that hole.
Dekorum
18
Sep 28, 2010 07:55 AM
mattbatson
Aug 10, 2009 11:42 AM
deadline
May 4, 2007 01:31 PM
RansteadSpecial
Jan 6, 2007 08:55 AM
eWock
Feb 3, 2006 11:10 PM
