Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
REAR CASTER
Old Jun 6, 2004 | 03:08 PM
Lo-Buck EF's Avatar
Default REAR CASTER
i guess this would only work on a mac strut car, but what would be the effects of caster (more or less) in the rear? i was having this discussion with a race car builder at work and he sais it has an effect, but wouldnt explain it to me.
-spenc
Old Jun 6, 2004 | 05:03 PM
Knestis's Avatar
Default Re: REAR CASTER (Lo-Buck EF)
There is no such thing, in a functional sense. Caster comes into play only as the wheels steer.
Suspension geometry can indeed change the toe and/or camber of a rear wheel dynamically but since this happens due to suspension travel, it is called "bump-steer" or "camber gain."
This is assuming that we are NOT talking about a Trophee Andros ice racer with 4WS, of course...
K
Old Jun 6, 2004 | 05:45 PM
TeamSlowdotOrg's Avatar
Default Re: REAR CASTER (Knestis)
Heh, I was just thinking along similar lines. "I wonder if they worry about rear caster when they're building the 4WS monster trucks..."
Old Jun 6, 2004 | 06:35 PM
Lo-Buck EF's Avatar
ok, that makes sence to me. i thought caster only shows in wheels that steer.
Old Jun 6, 2004 | 06:51 PM
577HondaPrelude's Avatar
Default Re: (Lo-Buck EF)
There are some old 4ws preludes, but I'm not sure how adjusting rear caster effects them...
Old Jun 7, 2004 | 05:30 AM
Jack Black's Avatar
There's a section in Puhn about rear caster. IIRC, it applies primarily to double-wishbone suspensions, and refers the angle between the upper and lower ball joints, same as in the front. It affects dynamic toe change, a.k.a bump steer.
L8APX
Mar 21, 2009 01:26 PM
VTEC_Du_Ma_Mai
Suspension & Brakes
30
Dec 4, 2008 05:19 AM
Silroan
May 23, 2004 06:13 PM
trhoppe
20
Aug 12, 2003 09:19 AM
