Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
::car pushing threw tight corners??::
Old Jun 6, 2004 | 02:43 PM
spock_rocker's Avatar
memoryFAB.com representative
Default ::car pushing through tight corners??::
i was just out in an empty parking lot dodging light poles and stuff(rookie season so i need all the practice i can get!).. well anyway when taking tight corners the car was pushing through... i got it so i could get threw the first part of the corner and give more throttle towards the end.. but im trying to figure out why it would be pushing so much?? i know this is a noob question. thanxx for your help!~
Modified by spock_rocker at 5:55 PM 6/6/2004
Old Jun 6, 2004 | 02:45 PM
Outrun's Avatar
Default Re: ::car pushing threw tight corners??:: (spock_rocker)
Wrong line, high entry speed? There are many factors that can be attributed to what you're going THROUGH.
Old Jun 6, 2004 | 02:47 PM
.RJ's Avatar
.RJ
Uhm... get out to some autocross events before you put your car threw a light pole.
If you turn in going to fast the car will push. Operator error.
Old Jun 6, 2004 | 02:56 PM
Default Re: ::car pushing through tight corners??:: (.RJ)
ive competed in a couple events now.. ive been through a class.. in not out driving like an idiot.. i was just wondering if a front sway bar would help. i figured i was taking the wrong line. thanxx
sorry!! i forgot to mention i cant spell!!
Old Jun 6, 2004 | 05:49 PM
Outrun's Avatar
Default Re: ::car pushing through tight corners??:: (spock_rocker)
Try playing with tire pressures too.
However, the biggest change comes from your technique. Try entering the corner differently by varying your line, braking, and driving style. Have you had an instructor ride along? They can offer you more tips.
Old Jun 6, 2004 | 05:51 PM
Tyson's Avatar
"pushing" through tight corners? solution is to take it slow. seriously.
now stop making a jackass of yourself in a parking lot. its not going to help you.
Old Jun 6, 2004 | 05:59 PM
MattG's Avatar
New User
Generally speaking, push is due to trying to turn while going to fast. Braking hard prior to the turn and then slowly squuueeeezing the gas as you straighten the wheel should be the first step in minimizing push.
I usually recomend learning how to drive your car as is and then adding parts as your skill level allows. A couple events is not much. Most good drivers have many years of experience. The learning curve on autocross is fairly steep. So take your time, have fun, and realize learning will take a long time.
A front sway bar probably would not help. Tires, rear sway bar, and more legal event seat time would be the best options.
Old Jun 6, 2004 | 06:06 PM
luder94-ChrisA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote"> i was just wondering if a front sway bar would help.
Adding a front anti-sway bar would probably increase the amount of push/understeer on your car. On a front-wheel drive car, Thicker rear anti-sway bars generally help to decrease push or create more oversteer
Old Jun 6, 2004 | 07:44 PM
CRX Lee's Avatar
If you were just playing around in a parking lot, then you probably didn't have a real course set up to drive through. If not, I'm imagining that you may be driving in hard, then turning the wheel and aggressively getting out. If so, you may be generating your own decreasing radius corners which would inherently induce understeer especially if you were coming in pretty hot. Simply not having a course to take a line through may have meant that your corners were not realistic and causing the push.
Old Jun 6, 2004 | 08:23 PM
Default Re: ::car pushing through tight corners??:: (CRX Lee)
thank you for the straight forward answers
tonykdee
Honda Civic (2001 - 2005)
May 23, 2007 10:49 PM
stRtypR25
Apr 23, 2006 12:19 PM
AKADriver
26
May 1, 2004 10:33 AM
MechE00
29
Sep 2, 2003 08:56 AM
