Where to get engine code reader????
Old Jun 6, 2004 | 12:55 PM
samssf's Avatar
Default Where to get engine code reader????
Hi - I need to check what code my engine light is throwing... does anyone know where I can get a reader and how much it will cost
Old Jun 6, 2004 | 12:57 PM
v4lu3s's Avatar
RTFM
any parts soter or dealer
they run $100+, usually around 150-200 for the basic ones.
Old Jun 6, 2004 | 01:02 PM
ABK's Avatar
ABK
Default Re: (v4lu3s)
You can pull the codes without that reader.
Old Jun 6, 2004 | 01:08 PM
shane12345's Avatar
Default Re: (ABK)
really?? I Need to do that also, how is it done? (I dont have much car knowledge)
Old Jun 6, 2004 | 01:09 PM
slomofo's Avatar
GDD Member
Default Re: Where to get engine code reader???? (samssf)
I got one from Snap-On for $4000, you can go to autozone and have them check it for free. If you just need codes, get it checked for free, if you need the scanner for other reasons, don't get the cheapo kind, they suck.
Old Jun 6, 2004 | 01:29 PM
BauleyCivic's Avatar
Risky Business
Default Re: Where to get engine code reader???? (slomofo)
What year/car do you have?
Old Jun 6, 2004 | 03:11 PM
shane12345's Avatar
Default Re: Where to get engine code reader???? (BauleyCivic)
98 civic EX
Old Jun 6, 2004 | 03:20 PM
shane12345's Avatar
Default Re: Where to get engine code reader???? (shane12345)
i cant find the service connector...
Old Jun 6, 2004 | 03:51 PM
93Civac's Avatar
Your going to need a OBD2 tester on your car. Go to a local parts store and see if they check it for free. If not take it to a dealership and they can pull the code for you.
Old Jun 6, 2004 | 04:34 PM
shane12345's Avatar
Default Re: (93Civac)
Yup got the code... P0700 and P0730 - transmission failure and improper gear ratio or some BS like that .... guess I'll have to take it to a tranny shop.. The car acts weird when I accelerate from a stop or accelerate when its changing gears... basically it hops sorta like if you are learning to drive a stick and arent working the gears right...
Old Jun 6, 2004 | 04:56 PM
Ricey McRicerton's Avatar
Default Re: (shane12345)
I have some software called AutoEngenuity on my laptop that connects though the OBDII port and a USB cable. Cost me like 220 or so. I love it. Not only does it read codes, but it also allows ou to datalog each of your sensors and watch them in realtime with a laptop.
Old Jun 6, 2004 | 05:43 PM
sauceracer247's Avatar
https://honda-tech.com/zerothread?id=682412
Old Jun 6, 2004 | 06:33 PM
biff's Avatar
Default Re: Where to get engine code reader???? (sauceracer247)
I just bought this one too dood for the palm pilot... it also dyno's your car, does 1/4 mile, 1/8, HP, RPM.. etc.. this fall they are supposed to be releasing some software ware that can alter the ECU through OBD2.. not sure how, but interesting
Old Jun 6, 2004 | 06:41 PM
pdiggitydogg's Avatar
Default Re: Where to get engine code reader???? (biff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biff &raquo;</TD></TR><TR><TD CLASS="quote">I just bought this one too dood for the palm pilot... it also dyno's your car, does 1/4 mile, 1/8, HP, RPM.. etc</TD></TR></TABLE>
Yeah...Im sure that works about as well as the *** dyno, as far as accuracy goes
ddevault1
Honda CR-V & Element
May 31, 2015 02:26 PM
mien_civic715
Aug 19, 2010 09:19 PM
LoGaN-VanG
Honda Civic (2001 - 2005)
Jul 1, 2009 08:18 PM
civic-4-ges
Jan 24, 2004 08:28 AM
