VAFC help
Old Jun 6, 2004 | 11:08 AM
Mr HYDE's Avatar
Default VAFC help
dont know whats goin on with it but every time i rev up and shift hard my vafc turns off and my vtec switches back to the primary lobes. i was haveing problems with vtec swtiching back cuz the vafc vtec control was set to low for my cams so now that it is at 55 on the vafc i think when it shuts off it reads from the ecu which is only 5 then swithces to primary lobes. any reason why its only turning off when switching gears hard ?????? i checked wirieing it seems alright but i dont know? the ecu is bolted down and not moving when i shift ??????????
Old Jun 6, 2004 | 11:22 AM
eg_type_r93's Avatar
Default Re: VAFC help (gen5hatch)
sounds like either a power wire or a ground wire because a sensor wire would not cause the vafc to turn off
Old Jun 6, 2004 | 11:26 AM
Mr HYDE's Avatar
Default Re: VAFC help (eg_type_r93)
theres 2 power wires red and orange i think and 2 ground black nad brown, i checked them both a couple times they seem good and makeing contact. this is so confuseing not know why this does this
Old Jun 6, 2004 | 03:01 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like either a power wire or a ground wire because a sensor wire would not cause the vafc to turn off</TD></TR></TABLE>
Yup, a sensor wire wouldn't turn it off, and if it was the MAP wiring it would cause the car to go into limp home mode. Check power/grounds.
Old Jun 6, 2004 | 09:40 PM
B20JonLee's Avatar
You mentioned it "seems like it is making good contact" ............. did you soldier and heatshrink all of your connections?
Old Jun 7, 2004 | 07:50 AM
0bd1_Kanobe's Avatar
Check the power and ground, sound like when your shifting somethings coming lose!!!!!!!!
Old Jun 7, 2004 | 09:21 AM
Mr HYDE's Avatar
Default Re: (BseriesHybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BseriesHybrid &raquo;</TD></TR><TR><TD CLASS="quote">Check the power and ground, sound like when your shifting somethings coming lose!!!!!!!!</TD></TR></TABLE>
ya im gona check it again just isnt makeing sense cuz the ecu is bolted adn not moving but ill check again
wicked_b16eg
Dec 30, 2007 11:10 AM
zeroek
Nov 23, 2005 11:51 PM
Shakes
Feb 26, 2004 01:39 PM
wgs0023
Feb 26, 2004 03:49 AM
Akkord29
Sep 13, 2003 08:29 PM
