wiring for JDM EF9 headlights...corner lights??
Old Jun 6, 2004 | 10:32 AM
dingusjt's Avatar
Default wiring for JDM EF9 headlights...corner lights??
ok how do I wire these bad boys up...i don't even see how I can fit it right, i did get the plugs and stuff from the ef9 apparently but those don't even look like they will fit??
Old Jun 7, 2004 | 06:56 AM
dingusjt's Avatar
Default Re: wiring for JDM EF9 headlights...corner lights?? (dingusjt)
up..i would like these things to work.
Old Jun 7, 2004 | 07:34 AM
schwanginpt's Avatar
well, if the EF9 headlights are anything like EF8 headlights, they are wider than stock, and the main thing is the headlights use H4H bulbs. use the EF9 harness, and you need to cut up your factory. JDM headlights use 1 bulb for both high and low beam - so 2 filaments in 1 bulb. what you need to do is hook up the low beam wires together and the highs together onto the EF9 harness, and attached the 2 grounds together. its pretty simple. but before you make final connections - test the lights to make sure the lows come on and not the high beams.
Old Jun 7, 2004 | 09:11 AM
EF_LSVtec's Avatar
Default Re: (schwanginpt)
exactly...colored wires matched up on mine, but its quite easy. JDM headlights have 3 wires, get lead from both your high and low beams and 1 for ground.
Old Jun 7, 2004 | 09:34 AM
dingusjt's Avatar
Default Re: (EF_LSVtec)
ok this is what i can tell, which maybe I don't have the JDM harness...
on the back of the headlight assembly there are simple three metal prongs, it appears that the headlight is rather solid in the back and so you change/remove bulbs by removing the front cover??
the prong setup is like this.
I
I I
i guess i just have to connect the bare wire from my existing headlights to these so what color wire goes to what prong???
Old Jun 7, 2004 | 10:45 AM
EF_LSVtec's Avatar
Default Re: (dingusjt)
IC...you dont have the 3 wire plug that fits the jdm headlight...I'm gonna have to check my wiring when I get home from work...unless someone here can help ya. You will probably have to get some kind of connectors to make this work (after we identify which wire goes where)
Old Jun 7, 2004 | 11:57 AM
dingusjt's Avatar
i know they make those single wire crimp connects that slip onto prongs...i just want to know which goes where..
but my car is being painted right now so no big rush.
Old Jun 9, 2004 | 04:04 PM
dingusjt's Avatar
nevermind I figured it out...ghetto rigged for now.
Old Jun 9, 2004 | 04:55 PM
87b16crx's Avatar
you might be able to clip the plugs off a 92-95 civic. they are a one bulb headlight.
lilazn71
Oct 13, 2007 11:38 AM
distronic
Jun 19, 2007 05:44 AM
Jthai
Mar 16, 2007 04:38 AM
SpleenBoy
Jun 7, 2006 12:07 PM
gsrintgra98
Jun 8, 2003 08:16 AM
