Need some help with distributor cel 9 problem
Old Jun 6, 2004 | 10:23 AM
Raggedyman's Avatar
Default Need some help with distributor cel 9 problem
I currently drive a '90 hatch with a '95 D16Z6 installed. Originally I listened to everyone and pulled the intake and replaced it with a '91 Si for the mini-me swap after doing the dpfi to mpfi swap. I used a '91 dizzy and ecu and the car ran great. Over 20k miles on it since the swap.
However, it was also a little weak and having to drive 65 miles each way to work with a weak car takes it's toll. So, finally, I got a P28 ecu and a dizzy (TD42U) that is supposed to be the right one. The ecu came from a manual car like mine so there should be no problems. I spent a week tracing down the wires and getting all the info I needed to change the wiring to OBD 1. Then I did the change.
Now I'm getting a cel 9 code.....CYP sensor. I'm not positive the dizzy is good/bad since I got it used, however, I can't find another one to try swapping at the moment. After messing with the grounds I was able to get rid of the cel 9, but only to get 2 more codes, cel 4 and cel 8 (crank angle and TDC). I went back and decided to rewire the dizzy all the way to the ecu using an 8 conductor, 4 pair twisted, shielded comm cable. I repinned the dizzy harness plug and landed the shield on the same brown/black wire that the original dizzy shield was landed on (B2 on the ecu). The dizzy end shield I tapped off and didn't land. I noticed the O2 sensor wire shield is also on the same brown/black wire at the ecu as well.
After starting, I got the same problem as before, cel 9. On a lark I decided to drive it down the road. She pulled harder than before and I was pretty happy even with the cel light on. I ran it up to 90 on the highway and came home. At the first stop light, it began to idle very poor and I couldn't rev hard at all or it would sputter. Nursing it, I made it home and rechecked the cel code. Now I also have cel 4 (crank angle sensor) and cel 9 (CYP sensor).
Does anyone know of any way to solve this problem? Am I on the wrong ground on the ecu (B2)? Any help would be greatly appreciated or else I'm going to have to go back to the original mini-me setup and I don't look forward to rewiring the ecu all over again. Thanks!
Old Jun 6, 2004 | 10:33 AM
Jared's Avatar
Default Re: Need some help with distributor cel 9 problem (Raggedyman)
it may just be the distributor. check the resistance on each reluctor inside the dist.
Old Jun 6, 2004 | 10:52 AM
Raggedyman's Avatar
Default Re: Need some help with distributor cel 9 problem (Jared)
Did that.....464 ohms across the CYP (orng and white)......457 ohms across the crank angle (blue/ylw and blue/green).....and 456 ohms across the TDC (orng/blue and white/blue) wires. The rpm signal (ylw/green) reads 4.5k ohms to ground. None of the signals in the distributor read to ground other than the rpm.
I can't find anywhere that says how much resistance I'm supposed to be reading.....are these readings low? Using a Fluke 87 btw, so I can't blame the equipment.
Thanks for the help!
Old Jun 6, 2004 | 11:05 AM
SiZ's Avatar
SiZ
When I had a code 9, I just replaced the distributer and it was gone.
Old Jun 6, 2004 | 11:13 AM
Raggedyman's Avatar
Default Re: (SiZ)
LOL....you can't imagine how badly I wish I had one right now just to try it....
Old Jun 6, 2004 | 01:18 PM
Raggedyman's Avatar
Default Re: (Raggedyman)
Oh my......I didn't really find the problem, but it seems to have disappeared. I tried every possible configuration of wires going to the dizzy until I couldn't even get the engine to fire. Slowly I worked my way back to the exact starting place where I began and VIOLA! it worked without any engine lights. All I can think is a loose connection in the dizzy plug. I also found a spot where the O2 sensor ground was still on the brown/black ground wire and I moved that.....however, that was early on during all my wire swaps so that could have had something to do with it.
Thanks everyone for your replies, I appreciate them!!
Vitamin G
Jun 16, 2012 06:03 PM
codrulz
Jul 10, 2009 03:00 PM
Eighty-Nyne
Sep 10, 2008 09:37 AM
HiProfile
Jul 23, 2005 08:38 AM
milanoGSR
Sep 25, 2003 07:07 AM
