Low idle..Searched. Please help.
Old Jun 6, 2004 | 10:15 AM
illicon2003
Guest
Posts: n/a
Default Low idle..Searched. Please help.
I'm pretty sure it's a problem only under braking, but I've noticed an extremely low idle recently.. especially once I've come to a stop light. I originally noticed these problems after replacing the 02 Sensor with an older one I had laying around (The CEL is off). The car is tuned up, everythings fine ignition wise. I did a search and I read that it could be a problem with the brake booster and air bubbles. I was told by the honda dealership that when working with power steering(Dumbass friend cut the hose), I'd need to bleed the brakes so as to eliminate air bubbles. I haven't done that, so could an air bubble in the brake booster cause the vaccum leak? Some other stuff I read about was adjusting idle and cleaning IACV, but I'm a little reluctant to do those since I've never done either before. Also, I just wired up an AFC last night. I'd like to iron out all these little problems before the turbo goes on, so it will be easier to fix problems associated with that. Please help me. thank you
PS: I just started the car up again and let it warm up, it stays around 500 and it somewhat rough.
Old Jun 6, 2004 | 11:08 AM
Re3irth's Avatar
Default Re: Low idle..Searched. Please help. (illicon2003)
theres so many things that can cause a low idle unfortunately.
Your gonna have to check those things your friends told you to
check. Below 600 idle the car will bogg and stutter
Old Jun 6, 2004 | 11:11 AM
HUBB's Avatar
Default Re: Low idle..Searched. Please help. (Re3irth)
my idle is **** as well....are u running a lightened flywheel, or a chipped ecu? the 9lb wheel + a chipped p28 =hubbs b18c idle to become shitty...
Old Jun 6, 2004 | 12:37 PM
illicon2003
Guest
Posts: n/a
No I'm not running either one of those. I have a feeling it has to do with either the afc, the 02 sensor, or possibly the alternator ( since PS fluid gets on it here and there, the hose is busted)
Old Jun 6, 2004 | 01:04 PM
HUBB's Avatar
Default Re: (illicon2003)
my 02 sensor is going so that may be it....keep me updated cus im still trying to figure out whats up with my **** idling funny.
Old Jun 6, 2004 | 01:10 PM
I'll cut ya!'s Avatar
Default Re: (HUBB)
ive got a 92 CX and i swear the idle is low. Theres no tach so i dont know for sure, and i dont know what the d15 idles at normally either. If i had to guess id say 600rpms.
Old Jun 6, 2004 | 02:32 PM
illicon2003
Guest
Posts: n/a
I Just realized it could be the spark plugs from when I was running real rich when the 02 sensor was messed up. It also could be the exhaust leak where the B pipe meets the muffler.
Old Jun 7, 2004 | 03:04 AM
illicon2003
Guest
Posts: n/a
could it be the throttle cable that's loose? Would that cause a low idle?
Old Jun 7, 2004 | 12:55 PM
illicon2003
Guest
Posts: n/a
????? Any reccomendations on what to start on fixing? thanks
Old Jun 17, 2004 | 07:29 PM
sohcSUCKS's Avatar
my d16y8 idles real low when im at stop lights, im talking about below 500 rpms almost to the last notch some times. I need help aswell.
Old Jun 18, 2004 | 04:01 AM
illicon2003
Guest
Posts: n/a
I checked the manual and it could be 3000 different things..I'm pretty sure it's my power steering pressure switch since I have the line cut
gagnebin
Honda Civic (2001 - 2005)
Nov 13, 2016 09:22 PM
Cambocheen!
Mar 23, 2009 12:09 PM
SpoonEk253
Nov 25, 2006 11:50 AM
beho
May 12, 2006 02:59 AM
MtnCRX
Jun 5, 2005 06:16 AM
