98 civic - SNAPPED STUD BOLT, HELP!!
Old Jun 6, 2004 | 08:46 AM
taejin11's Avatar
Default 98 civic - SNAPPED STUD BOLT, HELP!!
one of my studs snapped when i was taking my rim off to put on my sportlines
i figured out how to remove the rotor and caliper, but i need to somehow remove the front disc thingy to get my stud out...
how do you go about changing studs on a 98 civic ex 2dr?
thanx, i need help quick
Old Jun 6, 2004 | 08:50 AM
Davemel's Avatar
Default Re: 98 civic - SNAPPED STUD BOLT, HELP!! (devildicer)
if its the front, itll be hard to do your self. Best bet is to remove the whole hub and take it to les schwab or americas tire co. and let them do it.
Old Jun 6, 2004 | 02:43 PM
IVI's Avatar
IVI
Default Re: 98 civic - SNAPPED STUD BOLT, HELP!! (Davemel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davemel &raquo;</TD></TR><TR><TD CLASS="quote">if its the front, itll be hard to do your self. Best bet is to remove the whole hub and take it to les schwab or americas tire co. and let them do it. </TD></TR></TABLE>
are you serious?
what disc thingy are you talking about?
you said you figured out how to take off the rotor and caliper.
take them off and hammer the stud out.
put the new stud in, put a bolt of the right size so the lugnut when put over the stud has enough room to pull itself tight on the hub, but not so much room that it will damage the threads again.
this is definitly a do it yourself job.
Old Jun 7, 2004 | 07:50 PM
Davemel's Avatar
Default Re: 98 civic - SNAPPED STUD BOLT, HELP!! (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">
hes talking about the dust cover. to do it right you need to press the bearing out of the hub to get enough clearence to put in the new studs. Unless he has a press, hes going to have to have les schwab do it. I have seen people grind the back of the stud to get the clearance but thats half-assed.
simonEp3
Sep 3, 2008 04:49 PM
B18EG6
Nov 3, 2006 03:01 PM
accrd18
Mar 28, 2006 08:45 AM
gray_civic_coupe
Oct 25, 2005 11:22 AM
SL!M
Jun 2, 2003 06:20 PM
