Already searched... VTEC not kicking in...
Old Jun 6, 2004 | 08:14 AM
ShuaiGuy's Avatar
Default Already searched... VTEC not kicking in...
I've already searched and found some answers, but none have been the remedy. I had recently installed a VAFC II, fuel filter, and new cap and rotor. Everything was running fine, slightly rich, but that was fixed when i retorqued the fuel filter. VTEC was fine.
1 week later I threw on a Spoon 4-2-1 Header and Carsound Cat... and thats when the trouble begins. For whatever reason, VTEC isn't engaging anymore. I've checked the oil; level is fine and oil is clean. It isn't the MAP sensor either. I switched with a friend and still no VTEC. I checked all the wires on the VAFC II and it was fine.
Anyhow, I'm lost on where the next step is. According to the VAFC II vtec input and output is fine. Help me out people. I miss my VTEC... Thanks in advance!
If this helps... other mods include Comptech Icebox, Fuel Pressure Regulator, and Greddy SP exhaust. I thought maybe it was just quietly kicking in, but no pull at all.
Old Jun 6, 2004 | 08:16 AM
JiggyKooAndy's Avatar
Default Re: Already searched... VTEC not kicking in... (ShuaiGuy)
are you letting your engine warm up? as well as the oil (usually takes about 10 minutes in the summer) vtec won't kick in until the engine is warm enough; to prolong the life of the engine.
Old Jun 6, 2004 | 08:21 AM
RaVAGE00's Avatar
New User
Default Re: Already searched... VTEC not kicking in... (JiggyKooAndy)
Any check engine light after the header and cat install? Your car could be in limp mode.
Old Jun 6, 2004 | 08:32 AM
ShuaiGuy's Avatar
Default Re: Already searched... VTEC not kicking in... (RaVAGE00)
Yeah, I always let the car warm up. So I don't think thats it. See, I thought it was in limp mode too, but usually that involves not kicking in and not letting the car hit cetain rpm's. It's getting up there, just w/o VTEC. Thanks though.
Old Jun 6, 2004 | 09:29 AM
GSRswapandslow.
Guest
Posts: n/a
if vtec won't kick:
check oil level
check coolant level
check coolant temp switch
check vtec solenoid
check wiring
if it's not one of those...come back
Old Jun 6, 2004 | 09:59 AM
ShuaiGuy's Avatar
Default Re: (GSRswapandslow.)
Oil level was fine...
Coolant level is good...
Switch is looked fine...
Wiring was checked...
Vtec Solenoid... Some one help me out with this one!
Old Jun 6, 2004 | 10:23 AM
GSRswapandslow.
Guest
Posts: n/a
check the switch with a DVOM
and to check the solenoid...hook it up to a 12 volt source momentairly...it should click
Old Jun 7, 2004 | 06:15 AM
ShuaiGuy's Avatar
I gotta wait til tomorrow to check that out. Any other suggestions would be must appreciated! Thanks again guys.
Ntercooled
Dec 26, 2005 07:39 PM
DSoDry
Aug 13, 2005 12:32 PM
venger
Jul 6, 2005 11:10 AM
ShuaiGuy
Jun 8, 2004 11:10 AM
Variance
Jan 30, 2003 01:04 PM
