why do i keep blowing fuses?
My 98 civic DX keeps blowing the alternator fuse. Its causing my CEL to come on. Its throwing both o2 codes and the ELD. i replaced the primary O2 because it needed it.
last week this happened changed the fuse and i was fine. yesterday the light come on and i replaced the fuse. it blew 5 minutes later and light came on. i replaced the fuse agaon reset ECU and right away the fuse blew..
Is this a sign of a bad alternator?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">You could have a wire that is fried. That what was happening on my 98 civic dx. </TD></TR></TABLE>
In the Alternator?
My speedo is all figity, and then sometimes it works fine. i could be at a light and it will be jumping around all crazy
In the Alternator?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R »</TD></TR><TR><TD CLASS="quote">. i replaced the primary O2 because it needed it. </TD></TR></TABLE>
there was a 7.5 in there . ive tried multiple 7.5's and a few 10 amps.. , im thinking theres a bad wire in the alternator
i kept blowing fuses also. my problem was that the sec. o2 sensor wires shorted to the chassis of the car.
problems that it caused:
speedo went dead
speed sensor fuse blew
vtec didn't work
i replaced the fuse several times with the 7.5 fuse, but it kept blowing. i then put in a 15 amp fuse and drove it like this for a while, although the speed speedo never worked. i searched for a schematic of the vss and it seems like that thing is tied into several things. for ex, cruise control, alternator, vss, o2 etc. i troubleshot all those things but then i found that my sec. o2 sensor wires under my car near the shifter was grounding out to the car.
speedo went dead
vtec didn't work
i replaced the fuse again today at lunch. drove a few miles on my break. so far no light, but we will see. It just happens to be raining, so when it stops i will get it on stands and relook everything again..
Damn! I hate not having a garage anymore
Aaron Cayabyab
13
Jan 11, 2019 04:23 AM
LOWLIFEHATCH
10
Apr 25, 2006 10:33 AM
LOWLIFEHATCH
Apr 24, 2005 11:37 AM
